Rim-joist Insulation - Spray Or Sheet Foam? - Insulation - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 04:54 PM   #1
Rewards Points: 103
rim-joist insulation - spray or sheet foam?
Ive got about 60 joist bays to fill in the basement of our 40yr old ranch. its clearly drafty, so id like to get this taken care of.
Option 1 is sheet foam, cut to fit the bays, caulked/spray foamed in place
Option 2 is spray handi-foam (or similar).
Obviously #2 is easier, but its also about $350 vs about $50 for #1.
Will I be able to achieve equal results w/ #1 if i take my time and caulk/spray foam all the cracks,etc or is it really worth the extra 300 bucks? For what its worth, ill be in the house for another 5-7 years.
redline9k is offline   Reply With Quote
Old 11-28-2011, 09:40 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 894
Option 1, done properly/carefully, will work just as well.
What is your time worth? That is what it mostly comes down to.
The Following User Says Thank You to Windows on Wash For This Useful Post:
HomeSealed (01-12-2012)
Old 01-12-2012, 06:02 PM   #3
I can fix that!
Rewards Points: 35
I am currently doing this same thing and having trouble finding what type of foam board to use in the joist bays. EPS, EPS with film on each side, or XPS. I know XPS is recommended against basement walls. Also, the local big box stores in my area no longer seem to carry XPS.
kuhlman is offline   Reply With Quote
Old 01-12-2012, 06:11 PM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Why not just stuff it with regular insulation with a barrier?
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-12-2012, 06:38 PM   #5
I can fix that!
Rewards Points: 35
figured foam board with spray foam around the edges would give the best result (next to full spray foam). Just not sure what the best type of foam board would be.
Old 01-12-2012, 07:48 PM   #6
Registered User
Rewards Points: 4,924
I'd go with XPS and caulking. That foam board is not as open-cell as EPS to hold moisture leaking in from outside. Caulking would move with the rim joists (unless engineered wood) through the seasons; pp.51: http://books.google.com/books?id=iwS...rafter&f=false
Gary
The Following 2 Users Say Thank You to Gary in WA For This Useful Post:
Farmboy11 (01-22-2012), HomeSealed (01-12-2012)
Old 01-12-2012, 07:57 PM   #7
MarginallyQualified
Rewards Points: 2,464
its clearly drafty
Before you get to the joists... what's happening at the perimeter wall?
(gaps, cracks, ungasketed doors/windows, etc)
fwiw... I'd hate to any spray in foam used in basement level floor joists.
well, at lest not without first doing a TON of plumbing and wiring work
and so forth to minimize the chance I'd EVER deed to dig in later and if so to minimize the number of spots that would be likely to happen.
hth
Old 01-12-2012, 08:19 PM   #8
Furd's Avatar
Definitely use the extruded foam board insulation. The foil facing can be used as a vapor retarder under certain circumstances. If this is a living space then you will need to cover the insulation with a fire retardant barrier such as 1/2 inch gypsum board.
Furd is offline   Reply With Quote
Old 01-12-2012, 09:04 PM   #9
Home Performance
HomeSealed's Avatar
Rewards Points: 710
hth
That would only apply if he was planning to foam the entire floor (every bay), which is not the case..
On the rim joist, for cost, XPS and foam or caulk is the way to go... but be WARNED, this is a total PITA. For my money ( and time), I'd buy a froth pack (two-part portable spray foam) to hit those sill boxes. By far easier, and probably more effective.
I'd also mention that I dont believe that XPS/foam or caulk can be done for $50.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 01-12-2012, 09:08 PM   #10
Rewards Points: 89
I would (and did) use ROXUL to fill the cavities,virtually airtight,doesn't need a fireproofing cover (it is a fireblock).
And assuming cavities are at least 3 1/2 inches deep,you will get R-15 value insulation.
spring3100 is offline   Reply With Quote
Old 01-13-2012, 11:34 PM   #11
Registered User
Either one is an air barrier (much more important than the insulating qualities), unlike fiberglass or Roxul (work fine behind the air seal). Fig. #2 here: http://www.buildingscience.com/docum...ce-insulation/
Check locally, it may be able to be left uncovered (though the smoke is toxic), depending on location and year of the code used; http://publicecodes.citation.com/ico...016_par015.htm
Some hints if you DIY: http://www.sprayfoam.com/npps/story.cfm?nppage=123
Gary
Old 01-14-2012, 10:35 AM   #12
Rewards Points: 660
I am going to be a budinski for a second. Same topic different question. I am finishing of my basement in Minneapolis and plan on spraying the rim joists. 12" block, 10" joists, rim joists partially backfilled with concrete at build (1957).
My question is: do you foam spray to fill the entire rim joist cavity out to the framed basement wall (1" XPS board on wall) or do you just spray a 1-2" layer covering all surfaces?
B
Beepster is offline   Reply With Quote
Old 01-14-2012, 10:37 AM   #13
Rewards Points: 660
B
Old 01-15-2012, 09:39 AM   #14
Remodeling Contractor
Because any profession with building science knowledge will know that this will only trap moisture making the fiberglass ineffective and for mold to grow. Rim joists need to be air sealed and insulated to the same R-value your local codes require for the exterior walls. R19 in my area. Here is how I do rim joists http://www.homedoctorofamerica.com/rim-joists.
Your first solution (flash an batt works fine. Easy to use Roxul batt and spray foam. Or use polyicocyanurate foam board. Spray foam is much easier and is the only method I use.
Old 01-15-2012, 09:40 AM   #15
B
In your area use closed cell foam 3" thick
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 03:50 AM
DIY spray foam kits HitLines Building & Construction 4 03-18-2010 01:58 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
"effective" R-value for spray foam insulation? red86yota Building & Construction 1 04-23-2009 01:18 PM
