Rim Joist Insulation Options? - Insulation - DIY Chatroom Home Improvement Forum
Old 10-09-2012, 08:36 PM   #1
Rim Joist insulation options?
I'm getting ready to install a ceiling tile system in my basement, and friends have suggested that I install 'more' rim joist insulation before I do so..
The concept makes sense but I'm not sure what route I should go.
Currently I have 3/4" rigid (expanded) foam installed between the rim joists (unsealed, but I can fix that).. this was existing when I purchased the house..
Also I have exterior mounted 1/2" foil faced installed when new vinyl siding was installed. (The 1/2" foil faced was taped at the joints and extends down to the concrete foundation (covers the rim joists on the exterior)
So total insulation is:
1/2" foil faced - Rim Joist - 3/4" expanded foam board.
My friends have said.. "Just get some batten insulation and stuff it in there"..
Well everything I read says don't do that and note potential mold issues and reduced effectiveness... But all the examples assume you currently have no insulation... which I do have..
With the existing insulation in place will that batten work?, Or am I in for trouble down the road? or should I go the extra step and install 2" rigid foam..
Thanks for the input! ~Ian
learmoia is offline   Reply With Quote
Old 10-09-2012, 09:28 PM   #2
Rewards Points: 950
I think you have a decent thermal barrier in place and should proceed with the batts.
I regularly have 1" on the exterior and 1" or 2" on the interior (depending on scraps), then I put in some batts.
cleveman is offline   Reply With Quote
Old 10-10-2012, 12:09 AM   #3
Rewards Points: 1,092
Batts, esp fiberglass, are a poor choice here, as they would be exposed to air currents, killing their R value. Depending on where you are, more rigid or spray foam would be my suggestion. Too, you want to be careful sandwiching wood between layers of foam. If too thick, moisture is slow to leave the foam and can condense on the wood if it gets cold. Pick a side and insulate it; air seal, as you suggested you did on the outside.
Old 10-10-2012, 06:51 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,558
Spray foam and seal all the gaps in the EPS board that is in there now.
Install a Roxul batt in there as it will be a much tighter fit and will not suffer convective losses.
Old 10-11-2012, 12:02 AM   #5
Registered User
Rewards Points: 5,514
Caulk/canned foam the joints at rim to floor sheathing/mudsill to stop air movement. No rigid foam board inside, unfaced insulation only, fig 3: http://www.buildingscience.com/docum...ce-insulation/
Here it is again, fig. 10: http://www.buildingscience.com/docum...ding-basements
This shows foam on both sides...as JK said, Fig.2; http://www.buildingscience.com/docum...-at-rim-joist/
Because the wood rim (if solid wood) expands and contracts with the seasons, this cycling movement could break a shallow canned-foam seal around rigid foam board. Using spray foam is different because it would be 3" deep (about 3 times thicker than other), totally stopping any infiltrating/exfiltrating air. I would use 0.50# open-cell foam (SPF) because it "gives" more with movement with solid wood. If the outside foam board was perfectly applied (no air leaks; totally bonded), either foam would work.
Gary
Insulation options for 2"X4" roof framing Dave K Roofing/Siding 10 04-24-2011 11:42 PM
Drywall over foamboard rim joist insulation Atskodinski Building & Construction 0 01-19-2011 10:03 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
2 x 6 Cathedral Ceiling- options for insulation gfsdave Roofing/Siding 5 07-23-2008 07:46 PM
