Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 09-16-2012, 05:37 PM   #1
rim joist insulation
is the builder of my house required by code to insulate my rim joists
beattie is offline   Reply With Quote
Old 09-16-2012, 10:35 PM   #2
You did not add where you live in your profile.
It's always best to give your local code office a call with a question like this.
It's not required in my area.
Old 09-16-2012, 11:58 PM   #3
Moderator
If in the U.S. you probably are required to air seal AND insulate the rims. The "I" Codes require it; eg. #11; http://publicecodes.cyberregs.com/ic...002_par021.htm
5th down; http://publicecodes.cyberregs.com/ic...002_par022.htm
Even Joe's State requires it; IECC 2009; http://www.reedconstructiondata.com/...odes/virginia/
#11 again: http://publicecodes.cyberregs.com/ic...9_4_par025.htm
5th down again: http://publicecodes.cyberregs.com/ic...9_4_par026.htm
Either caulking or canned foam to air seal, wall (usually) thickness insulation on rim. Always check with local AHJ.
Gary
Clothes taking longer to dry?
Floor joist insulation help Drewkernovich Insulation 3 01-05-2012 10:50 AM
insulation of rim joist sherryne Building & Construction 1 01-04-2011 01:12 PM
Floor joist insulation Arky217 Building & Construction 0 12-29-2010 12:56 PM
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 02:30 PM
Rim Joist Insulation ja191992stg Building & Construction 53 03-22-2010 09:41 PM
