-   Insulation (http://www.diychatroom.com/f103/)
-   -   rim joist insulation (http://www.diychatroom.com/f103/rim-joist-insulation-156992/)
beattie 09-16-2012 04:37 PM
is the builder of my house required by code to insulate my rim joists
joecaption 09-16-2012 09:35 PM
You did not add where you live in your profile.
It's always best to give your local code office a call with a question like this.
It's not required in my area.
Gary in WA 09-16-2012 10:58 PM
If in the U.S. you probably are required to air seal AND insulate the rims. The "I" Codes require it; eg. #11; http://publicecodes.cyberregs.com/ic...002_par021.htm
5th down; http://publicecodes.cyberregs.com/ic...002_par022.htm
Even Joe's State requires it; IECC 2009; http://www.reedconstructiondata.com/...odes/virginia/
#11 again: http://publicecodes.cyberregs.com/ic...9_4_par025.htm
5th down again: http://publicecodes.cyberregs.com/ic...9_4_par026.htm
Either caulking or canned foam to air seal, wall (usually) thickness insulation on rim. Always check with local AHJ.
Gary
