Rim Joist Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 05-01-2012, 12:05 AM   #1
Rim Joist insulation
I've been adding foam board with Great stuff in the rim joists. But, I've got some overhangs where some A/C vents go into and there isn't enough room to properly install the XPS with great stuff around it. What is the best way to insulate around the A/C vents?
In this case, the joists go about 2' past the foundation.
sile16 is offline   Reply With Quote
Old 05-01-2012, 12:14 AM   #2
Rewards Points: 14,020
Just stick some fiber glass insulation in the best you can. It's Got to better then it was when your done.
Old 05-01-2012, 08:34 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,270
Roxul or Fiberglass.
Roxul is more air impermeable than fiberglass and a bit easier to cut into shapes.
Old 05-01-2012, 08:17 PM   #4
Rewards Points: 236
what is on the other side of the foundation ?
Fix'n it is offline   Reply With Quote
Old 05-01-2012, 09:53 PM   #5
Registered User
Rewards Points: 526
See if that register boot will push upward after removing the nails in the sub-floor to install the f.b. Just tin snip off the extra or buy a close-bend boot. Ideally. for optimum value would be adding f.b below the joist bottoms and replacing the soffit wood outside. This would prevent "radiation" and provide a thermal break from the ground/outside air temp. and the joist which is R-1.25 per inch.....http://www.buildingscience.com/docum...n-crawlspaces/
Gary
Old 05-06-2012, 09:38 PM   #6
Trucon01's Avatar
Rewards Points: 510
When insulating the rim joist do you:
1. Cut foam to fit rim and spray foam around it
OR
2. Caulk rim, insert foam and then spray foam?
Trucon01 is offline   Reply With Quote
Old 05-09-2012, 11:12 PM   #7
Registered User
Rewards Points: 526
#2 to air seal the rim as it expands/contracts with the seasons; pp.51, http://books.google.com/books?id=iwS...rafter&f=false
http://www.buildingscience.com/docum...l_seal_rev.pdf
http://www.conservationtechnology.co...eakagePathways
Gary
Old 05-10-2012, 07:04 AM   #8
Trucon01's Avatar
Rewards Points: 510
Thanks Gary. You've been a huge help with all of my projects so far...
The Following User Says Thank You to Trucon01 For This Useful Post:
Gary in WA (05-11-2012)
Old 05-15-2012, 07:57 AM   #9
Trucon01's Avatar
Rewards Points: 510
Here is my progression with the rim joists.
I also have a basement project where you can see the whole project...
2012 - Basement demo
Old 05-15-2012, 08:30 AM   #10
Rewards Points: 2,516
spray foam works good also
hammerlane is offline   Reply With Quote
Old 05-15-2012, 08:37 AM   #11
Trucon01's Avatar
Rewards Points: 510
Indeed. How much did that run you for just your rim joists?
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Old 05-15-2012, 08:59 AM   #12
$800 for 166 lineal feet of rim joists and a 200 sq foot of wall space in an attic area above a garage.
Attached are a few photos:
The top 3 are of the attic area above the garage. The last is my basement setup.
After they did the spray foam in the attic area I fluffed up all existing batt insulation and laid new batts across the joists.
Old 05-15-2012, 05:26 PM   #13
Just a DIY guy
You have a chandelier in the attic? Very classy.
M3 Pete is offline   Reply With Quote
The Following 2 Users Say Thank You to M3 Pete For This Useful Post:
drtbk4ever (05-17-2012), Ravenworks (05-15-2012)
Old 05-15-2012, 06:10 PM   #14
Yeah right. Took it out of the dining room when we moved in and put in a ceiling fan. Been trying to sell it but no takers yet. Figured its safer in attic than down in basement.
Actually the 1st photo below shows when I still had batt insulation in the rim joist cavities.
Old 05-15-2012, 10:54 PM   #15
Registered User
Rewards Points: 526
Looks good! I was surprised while researching that 1/16" air gap will admit moisture to the rim joist. Just caulk the joints/small holes the SPF missed.
If the attic is not used for storage or attics not joined, an ignition barrier only is required over the SPF for fire-safety;http://publicecodes.citation.com/ico...016_par007.htm
if used for storage; a thermal barrier is required per Code: http://publicecodes.citation.com/ico...016_par003.htm
Some foams are acceptable, ask your local Building Department.
Is there soffit venting, as I don't see the air chutes there?
Gary
Floor joist insulation help Drewkernovich Insulation 3 01-05-2012 09:50 AM
insulation of rim joist sherryne Building & Construction 1 01-04-2011 12:12 PM
Floor joist insulation Arky217 Building & Construction 0 12-29-2010 11:56 AM
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 01:30 PM
Rim Joist Insulation ja191992stg Building & Construction 53 03-22-2010 08:41 PM
