Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 03-22-2011, 09:53 PM   #1
Question
rigid insulation thickness for a condo/townhouse
i used 2"blue rigid insulation on the 2 exterior walls (front and rear of unit)
which gives me r10 and framed in front of that and filled with roxul safe n sound.
but for the divider walls ( we are an inside unit ) how thin (r value?) can i go...
1/2 " pink has a r3 and goes up from there
im in kitchener ontario so im trying to do it to code
any help would be great
goldberg245 is offline   Reply With Quote
Old 03-22-2011, 10:00 PM   #2
concretemasonry's Avatar
Why would you want to insulation the interior walls from the heat of the adjacent unit?
The only reason, I could think of would be to Roxul for reduced noise transmission between units.
Dick
concretemasonry is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
rigid foam or batt insulation mjsparky363 General Discussion 0 01-31-2011 07:35 AM
rigid insulation in basement belindapotter Carpentry 3 01-22-2011 01:01 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
Covering rigid foam insulation in furnace area looking4ideas Building & Construction 4 12-30-2009 06:49 AM
