Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 01-21-2013, 09:57 PM   #1
Rigid Insulation to insulate and create attic floor.
I have a 1928 house with the original insulation mat in the attic. A portion of the attic has been floored over with plywood. I was thinking of pulling up the plywood and adding layers of polystyrene sheets for increased R value and then putting the plywood back over the XPS to maintain surface to store stuff on. Is this a feasible solution?
djs26 is offline   Reply With Quote
Old 01-24-2013, 10:15 PM   #2
Moderator
Welcome to the forums! I would not use the attic as storage. Gary
Clothes taking longer to dry?
Old 01-24-2013, 10:34 PM   #3
That would also form a vaper barrier on the wrong side which can trap moisture and cause mold.
Old 01-25-2013, 06:38 PM   #4
Moderator
If you must, and in a heating climate: pp. 24 and read the article, air seal first, etc.; http://www.buildingscience.com/docum...ation-packages
Gary
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Insulating your attic Bob Mariani How To Guides 2 03-01-2012 06:56 PM
Floor joist insulation support Arky217 Building & Construction 2 05-24-2011 05:48 PM
Cellulose Insulation Questions... Master Brian Building & Construction 13 09-07-2010 09:09 PM
Rafter Vents and Insulation nofx1981 Roofing 15 03-10-2010 09:14 PM
