-   Insulation (http://www.diychatroom.com/f103/)
-   -   Rigid Insulation to insulate and create attic floor. (http://www.diychatroom.com/f103/rigid-insulation-insulate-create-attic-floor-169768/)
djs26 01-21-2013 08:57 PM
I have a 1928 house with the original insulation mat in the attic. A portion of the attic has been floored over with plywood. I was thinking of pulling up the plywood and adding layers of polystyrene sheets for increased R value and then putting the plywood back over the XPS to maintain surface to store stuff on. Is this a feasible solution?
Gary in WA 01-24-2013 09:15 PM
Welcome to the forums! I would not use the attic as storage. Gary
joecaption 01-24-2013 09:34 PM
That would also form a vaper barrier on the wrong side which can trap moisture and cause mold.
Gary in WA 01-25-2013 05:38 PM
If you must, and in a heating climate: pp. 24 and read the article, air seal first, etc.; http://www.buildingscience.com/docum...ation-packages
Gary
