Rigid Form Board And Fire Retardant - Insulation - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 01:47 PM   #1
Rewards Points: 324
Rigid Form Board and Fire Retardant
Hello,
I have an attic area that shares an interior wall. Rather than just putting fiberglass batt, I thought about placing rigid form insulation against the attic facing wall to minimize wind washing? The area is most similar to a knee wall. The question I have is whether I need to place some fire retardant over the rigid foam and if so what do I use other than drywall? I thought I heard FSK 25 paper was fire retardant but I could be wrong.
To complicate the matter, there is direct fireplace vent that runs close to the foam but still 2" away which concerns me.
Thanks!
sbkim is offline   Reply With Quote
Old 07-24-2012, 07:49 PM   #2
Too Short? Cut it Again!
In most cases, I believe code will require that you drywall it. The paper will unlikely be viewed as a sufficient fire barrier. Why are you opposed to fiberglass batts? If you have ever seen a piece of non fire rated foam ignite and melt you would not want it in your home without a fire block!
Old 07-24-2012, 07:53 PM   #3
Rewards Points: 324
Sorry for not making it clear. I am definitely putting fiberglass batt (r 21) I want to add sheathing as well. I thought rigid foam would add more r value but concerned with fire code. So would you recommend drywall on both sides of this common wall?
Old 07-24-2012, 08:42 PM   #4
I am saying that with non fire rated foam I think you will have to drywall both sides. Check with your building department. I could be wrong.
Old 07-25-2012, 07:47 AM   #5
Rewards Points: 324
Other than Thermax are there any other fire rated rigid foam or less expensive way to make it such without using drywall?
plywood on fire rated wall acerunner Building & Construction 9 11-18-2016 07:15 PM
Air Sealing Subfloor Joist Space - Foam Board? masonbrown Insulation 2 05-06-2012 04:54 PM
New control board or fix it? Bobeht HVAC 26 01-18-2012 04:03 PM
fire barrier for foam board insulation jcomp Building & Construction 1 12-12-2010 08:03 AM
Polystrene (DOW) Rigid Insulation board - fireproof AndrewF Building & Construction 8 11-28-2010 02:17 PM
