Rigid Foam Up To Subfloor On Basement Wall. What To Do Behind It? - Insulation - DIY Chatroom Home Improvement Forum
Old 01-16-2014, 02:48 PM   #1
Rewards Points: 1,426
Rigid foam up to subfloor on basement wall. What to do behind it?
Not sure if the pic will work. Third pic here:
http://basc.pnnl.gov/resource-guides...blocks-block-2
What are the options for insulating behind this in the rim joist area? Fiberglass batts ok? Bad idea? I know roxul is a better alternative, but I'd like to know all the options. Thanks.
mikegp is offline   Reply With Quote
Old 01-17-2014, 06:25 PM   #2
Registered User
Rewards Points: 4,924
Fiberglass batts are OK (as you already have the best one between cold/warm now), Roxul is better- if only from a sound control/wetting performance. I would leave a small air gap between the two insulations or add minimal fibrous batt tight to the FB. The more cavity fill (in front of the foamboard) the colder the FB will be. You would be slowing the heat reaching the inside face of the FB= colder FB= more chance of condensation as it lowers the dew-point there, Fig. 4; http://www.buildingscience.com/docum...nsulation/view
Did you cover the top of concrete wall against the mudsill plate?
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Windows on Wash (01-18-2014)
Rigid foam on basement walls - gap or no gap? spaceman spif Insulation 9 10-19-2013 05:40 PM
Re-thinking my basement wall insulation system 1jumper Insulation 15 10-26-2011 04:06 PM
Anchor in rigid foam insulated wall imjoking Building & Construction 2 10-17-2011 10:53 PM
rigid foam board on basement floor is it good or bad cutnail Insulation 6 08-29-2011 08:48 AM
Best way to insulate basement in cold Canadian climate dtran Building & Construction 1 07-08-2009 08:48 PM
