-   Insulation (http://www.diychatroom.com/f103/)
-   -   Rigid Foam Under Rat Slab (http://www.diychatroom.com/f103/rigid-foam-under-rat-slab-167886/)
tomdor 12-31-2012 03:01 PM
Okay, so I've searched the web and searched through this forum and can't find the answer to one question I have.
I will be pouring a rat slab into my crawl space to prevent the persistent buggers from tunneling under my footing. I also plan to make this a conditioned crawl.
Should I pour the rat slab over rigid foam? Would it make a difference? I'm in climate zone 4c (Seattle)?
Thanks!
Windows on Wash 12-31-2012 04:23 PM
Why kind of rigid foam?
I can't hurt.
Gary in WA 12-31-2012 09:38 PM
http://www.house-energy.com/Insulati...Insulation.htm
http://www.wrcc.dri.edu/cgi-bin/cliGCStH.pl?watac1
Gary
PS. install 6mill poly under the whole slab first...
tomdor 01-01-2013 11:25 AM
Happy New Year and thanks for the great info in the links!
I was planning on using XPS but do you know if I can use R-Matte Plus ISO?
Windows on Wash 01-02-2013 08:44 AM
Use XPS under the slabs.
ISOs are moisture sensitive.
Gary in WA 01-02-2013 09:31 PM
The foil-facing is good IF there is a space, but not with a slab over it.... Just don't puncture the foil with rocks or pea gravel (in the concrete mix), hmm.....; http://www.inspectapedia.com/Energy/...urate_Slab.htm
Or it can/will absorb 7 times more water in the test as XPS; http://commercial.owenscorning.com/a...35d75090ec.pdf
Gary
tomdor 01-03-2013 01:02 PM
hmm yeah...my experience with the foil is that if often gets a small puncture if you look at it the wrong way.
Thanks for the add'l info:)
