Rigid Foam And Fiberglass - Insulation - DIY Chatroom Home Improvement Forum
Old 10-04-2012, 06:09 PM   #1
mrtn's Avatar
Rigid foam and fiberglass
I have been doing a ton of research and thought I finally had my plan. 2" xps rigid foam against the concrete, framing against that, fill 16" space with fibreglass insulation, then dry wall. Then I read on another contractors forum that I need a vapour barrier before I put up the drywall. I never really thought of it, but after reading more I'm getting conflicting ideas.. Typical. What are the opinions? Isn't the 2" foam good? Or because I'm adding insulation do I need a vapour barrier on the warm side? I thought this would trap moisture in between?
mrtn is offline   Reply With Quote
Old 10-05-2012, 07:05 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,676
Depending on the foam, this would create a vapor trap.
While it may not be code, I personally think that the method you are looking at is the more proper and will keep the inside of that wall assembly warm enough that condensation will be a non issue.
Make sure the drywall layer is completely air tight and maybe use and air barrier like a tyvek and you should be fine.
Bulk air loss moves 50X as much moisture as does diffusion so if you stop that, that is what will keep the walls dry.
Old 10-06-2012, 10:15 PM   #3
Registered User
Rewards Points: 5,516
Check locally, and starting on pp.15; ftp://ftp.cmhc-schl.gc.ca/chic-ccdh/..._Web_sept5.pdf
Gary
Old 10-07-2012, 08:33 PM   #4
mrtn's Avatar
Thanks, an interesting read yet once again, never a straight answer.
Old 10-08-2012, 08:58 PM   #5
Braddiy's Avatar
Angry
i have read conflicting reports as well the first one being that foam/rigid insulation is your vapour barrier then i read that this creates a moisture problem from lower basement wall to the top portion of basement wall. condensation caused by temperature changes and trapping the moisture.
sign confused!
good luck
Last edited by Gary in WA; 10-08-2012 at 09:34 PM. Reason: To keep our "G" rating.
Braddiy is offline   Reply With Quote
Old 10-08-2012, 09:38 PM   #6
Registered User
Unless there is plenty of foam air-sealed to the concrete wall, a vapor barrier/retarder is not needed. I have many links, all different (other than no vapor barrier) but just leave you with the best one. Find the different wall compositions and read about the vapor/moisture for that specific wall. The front part links to the back half; http://www.buildingscience.com/docum...study-analysis
Gary
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Is spray foam insulation that much better than fiberglass? HautingLu General DIY Discussions 18 09-21-2010 06:36 PM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 02:50 AM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 07:48 PM
Diference between Fiberglass and Hard Foam shumakerscott Roofing/Siding 3 09-06-2008 12:16 PM
