Rigid Foam Boards Installation In Garage - Insulation - DIY Chatroom Home Improvement Forum
Old 03-11-2014, 10:55 AM   #1
Rigid foam boards installation in garage
Hi,
My garage walls and ceiling have sheetrock and then a thin layer of concrete on top of it. I want to insulate my garage and my idea is to glue and fasten foam boards on the walls and the ceiling (with most likely drywall screwed onto the foam boards). What is the feasibility of this?
Also, I read that the foam boards are flammable, is it dangerous to use them around electrical switches, outlets ?
Thanks a bunch!
1489 is offline   Reply With Quote
Old 03-11-2014, 11:07 AM   #2
Rewards Points: 12,804
Why would there be concrete over the sheetrock? Sure it's no just someone's attemt to get out of finishing the drywall and just textured it?
Foam board gives off toxic fumes when it's exposed to heat that why it needs to be covered.
Outlets and switches should never be getting hot.
What your suggesting is not a great way to be doing this.
What are you going to do around all the outlets, switch's, window and door opening with the walls built out like that?
Is the area over the ceiling exposed? If so insulate over the sheetrock not under it.
The walls need to be insulated inside the wall cavity.
Old 03-11-2014, 02:09 PM   #3
Yes, thank you. I see how its a really bad idea. My garage walls are esthetically in pretty bad shape and i want to make it look nice. My other thought was to add furring strips and then placing drywall on them (I dont want to tear the old existing drywall with the product on top). Can I place the furring strips on my wall foundation (which will have a vap barrier) and then place drywall on the strips ? Is there any issues in doing so?
If this is also a bad idea, any idea on how to improve the look of my garage walls without tearing the old drywall down??
Thanks!
Old 03-11-2014, 03:54 PM   #4
Rewards Points: 150
is the garage attached to the house?
hpyjack2013 is offline   Reply With Quote
Old 03-11-2014, 05:39 PM   #5
What's the big deal about removing what there and doing it right?
Old 03-11-2014, 05:48 PM   #6
Rewards Points: 16
use hardi panel
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Tags
boards , foam , garage , installation , insulation
Removal of support boards above the garage dajate Building & Construction 10 11-10-2012 02:19 PM
Basement insulation - 2" rigid foam diggerd Insulation 5 10-09-2012 08:24 AM
Nailing Rigid Foam Boards to Plywood Buscador Roofing/Siding 5 02-05-2012 07:22 PM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 08:48 PM
Rigid foam as floor insulation rkhpapa Building & Construction 3 09-24-2006 07:06 PM
