Rigid Foam Board - Insulation - DIY Chatroom Home Improvement Forum
Old 02-07-2013, 01:38 PM   #1
Rigid Foam Board
I plan on putting rigid foam on basement walls. Live in NJ. Any difference between Owens Corn Foamular vs Dow Styrofoam? Plan on using 2inch. Only difference I see is price and color and brand. Anything I am missing? Thanks
echonewyork is offline   Reply With Quote
Old 02-07-2013, 01:50 PM   #2
"You can do anything"-Mom
brockmiera's Avatar
Are they both XPS? The Dow I've seen at HD is EPS and has a lower installed R value.
brockmiera is offline   Reply With Quote
Old 02-07-2013, 05:04 PM   #3
I believe they are both XPS
Old 02-07-2013, 05:06 PM   #4
Trucon01's Avatar
Rewards Points: 510
Around here, HD carries the pink Owens Corning and Lowes carries the light green Dow XPS. If both are XPS, both should be rated the same
1" = R5
2" = R10
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 02-07-2013, 07:01 PM   #5
GBrackins's Avatar
Rewards Points: 2,108
for your reading pleasure ..... I myself prefer the Dow, but do your homework do you know what's what
http://building.dow.com/na/en/produc.../rigidfoam.htm
http://msdssearch.dow.com/PublishedL...romPage=GetDoc
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
echonewyork (02-07-2013)
Old 02-07-2013, 11:02 PM   #6
Registered User
Rewards Points: 526
One absorbs 3 times water, what type of OC? One retains 96% R-value, another 98%..
Gary
Old 02-08-2013, 05:11 AM   #7
Which absorbs more? DOW? Which do you recommend Gary? Whats OC? Sorry, got a newbie here. Learning day by day
Old 02-08-2013, 07:27 AM   #8
OC = Owens Corning I believe.
Trying to figure out the shorthand here on these forums can be challenging!
PS. Don't take my guess as gospel---- it is my guess.
VonTed is offline   Reply With Quote
The Following User Says Thank You to VonTed For This Useful Post:
echonewyork (02-08-2013)
Old 02-08-2013, 07:32 AM   #9
Foamular OC 250. 2inch
Old 02-08-2013, 07:36 AM   #10
Its either OC foamular 250 2in or Dow Styrofoam square 2in. OC for $37 per 4x8 and Dow for $50 4x8. Dont mind the price diff if im getting a better product.
Old 02-10-2013, 07:58 PM   #11
Registered User
Rewards Points: 526
For that big of a price difference, figure them equal. The water absorption test is less with OCorn. = 0.10 and Dow= 0.30... not a biggie considering water vapor will keep the board saturated most the year anyway, lol. They used to be the same company till one branched off. Be sure to use a closed grid glue pattern on the concrete, to reduce any air leaks inadvertently made when installing it. Add some 1/2" EXP under the frame wall bottom plate for a thermal/air/capillary break. Air-seal the rim joists with canned foam using extra 2". Use a latex based paint on the drywall. Pictures when done... we love pictures!
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
echonewyork (02-10-2013)
Old 02-12-2013, 07:22 AM   #12
Any tape to seal the foamboard edges to each other or tongue and groove enough? By the way, Gary, your posts are simply great.
The Following User Says Thank You to echonewyork For This Useful Post:
Gary in WA (02-12-2013)
Old 02-12-2013, 09:26 AM   #13
Rewards Points: 1,498
I use Tyvek tape. About $11 a roll at HD. You definitely want to seal the seams.
mikegp is offline   Reply With Quote
Old 02-12-2013, 09:51 AM   #14
brockmiera's Avatar
+1 for Tyvek tape. That stuff is awesome!
Old 02-12-2013, 10:22 AM   #15
Registered User
Rewards Points: 526
I'd use canned foam or furnace duct mastic/mesh tape for total air-seal. The c. foam is more flexible, or use some quality caulking or better still; acoustical sealant (best); http://www.liquidnails.com/products/...-sealant-AS825 under the overlap that can give-some with slight movement. The foam boards shrink over time (aging); http://www.buildingscience.com/docum...a-foam-shrinks Just like a rim joist, it's the air leak that will give up the moisture in condensation; http://www.buildingscience.com/docum...l_seal_rev.pdf Of coarse on a wall, the air is going from inside to wall, not both ways as in rim. ADA the drywall to stop air at the first line of defense; http://www.buildingscience.com/docum...wall-approach/
Gary
PS. after that, I just HAD to use more links, lol.
Rigid (XPS) Foam Board Size for basement. fastmodena Insulation 6 12-03-2012 09:42 PM
rigid board and framing need gap? s002wjh Building & Construction 4 01-30-2012 09:32 PM
Best adheasive for foam board to concrete BlueBSH Building & Construction 1 08-05-2011 03:06 PM
Leveling Basement Floor Rigid Foam mdenis Building & Construction 6 09-07-2009 04:55 PM
XPS foam board between basement slab and cement board for ceramic tiles jpsmith Flooring 4 02-10-2009 08:17 PM
