Rigid Foam On Attic Floor? - Insulation - DIY Chatroom Home Improvement Forum
Old 06-28-2012, 12:31 PM   #1
Rigid Foam on attic floor?
I need extra insulation in my attic which is a cold space, I was thinking of putting down the rigid foam on the floor surfaces and screwing it into the sub floor to help boost the insulation. Does anyone know if this is a good option..
rihal1958 is offline   Reply With Quote
Old 06-28-2012, 01:34 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,926
I must be covered with a proper thermal barrier in most cases and why use rigid foam where blown in cellulose would work just fine?
The Following User Says Thank You to Windows on Wash For This Useful Post:
rihal1958 (06-28-2012)
Old 06-28-2012, 03:01 PM   #3
AGWhitehouse's Avatar
+1 with WOW...go with a blow-in or batt. product and you can cover it all with a tyvek like material (class III vapor retarder MAX.) to help mitigate air movement through the fibers. It is cheaper too!
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
The Following User Says Thank You to AGWhitehouse For This Useful Post:
Old 06-29-2012, 01:11 AM   #4
Registered User
Rewards Points: 5,216
1. Where are you located?
2. Is there HVAC in the attic?
3. Do you plan on storing household goods up there?
Gary
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Floor insulation, cellulose vs hard foam Arky217 Flooring 0 12-23-2010 11:44 PM
Insulating attic with rigid foam giannit Building & Construction 0 01-08-2010 11:39 AM
Insulating my attic using 4X8 rigid foam board Vermont1 Building & Construction 8 04-30-2009 12:15 PM
How do I get from the upstairs attic down to my 1st floor? diyintexas Electrical 8 09-29-2008 06:05 PM
