-   Insulation (http://www.diychatroom.com/f103/)
-   -   Rigid Foam on attic floor? (http://www.diychatroom.com/f103/rigid-foam-attic-floor-148494/)
rihal1958 06-28-2012 11:31 AM
I need extra insulation in my attic which is a cold space, I was thinking of putting down the rigid foam on the floor surfaces and screwing it into the sub floor to help boost the insulation. Does anyone know if this is a good option..
Windows on Wash 06-28-2012 12:34 PM
I must be covered with a proper thermal barrier in most cases and why use rigid foam where blown in cellulose would work just fine?
AGWhitehouse 06-28-2012 02:01 PM
+1 with WOW...go with a blow-in or batt. product and you can cover it all with a tyvek like material (class III vapor retarder MAX.) to help mitigate air movement through the fibers. It is cheaper too!
Gary in WA 06-29-2012 12:11 AM
1. Where are you located?
2. Is there HVAC in the attic?
3. Do you plan on storing household goods up there?
Gary
