Retrofit Attic Baffles With Blocking In Open Eaves - Insulation - DIY Chatroom Home Improvement Forum
Old 09-24-2011, 08:05 PM   #1
jkk
Rewards Points: 233
Retrofit attic baffles with blocking in open eaves
Now that I have a ridge vent I need to install some soffit vents and baffles. I currently have 2x6 joists with (almost) vertical 2x6 blocking, blown insulation and open eaves. I've thought about using Accuvent baffles but I'm not sure what to do with the blocking. I could cut holes in tge blocking and put in some 4" round vents ... would be lots of drilling, maybe 50-60 holes to get proper area.
Any alternative suggestions?
jkk is offline   Reply With Quote
Old 09-24-2011, 09:37 PM   #2
DIY staff
Rewards Points: 7,174
Post a picture if you can---not familiar with the locking you are describing.
Old 09-24-2011, 10:04 PM   #3
jkk
Rewards Points: 233
Originally Posted by oh'mike View Post
Post a picture if you can---not familiar with the blocking you are describing.
Attached. Proposed locations for 4" vents shown.
Old 09-25-2011, 09:31 AM   #4
DIY staff
Odd framing feature----are those blocks visable from the outside?
Your round vent idea sounds good---tedious job---might be someone else has a better solution--
Let's see----mike---
Old 09-25-2011, 09:57 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,674
I think you are on the right track.
What is the rest of the venting in the attic like? Do you have condensation issues?
Old 09-25-2011, 10:06 AM   #6
jkk
Rewards Points: 233
Odd framing feature----are those blocks visable from the outside ?
Not really visible as they're painted dark brown. You can only see them if you're under the eave and looking up.
Old 09-25-2011, 10:09 AM   #7
jkk
Rewards Points: 233
Gable vents which I plan to at leawst temporaily close to see what happens to attic temps. Checking the temperature seems easy with an infrared sensor.
No condensation problems, even with family of 7 and lots of home cooking.
Old 09-25-2011, 10:11 AM   #8
jkk
Rewards Points: 233
After further review ... I may have to abandon the Acccuvents since I don't have access to the vertical face of the plate (drywall in the way). Maybe I'll just have to accept using the styrofoam baffles.
Old 09-25-2011, 11:07 AM   #9
jkk
Rewards Points: 233
After more review, the round vents won't help much as the blown insulation covers the back of the 2x6 blocking. So, in order to get in air to flow on top of the baffle, maybe cuting out a strip or some pieces at the top of the blocking and installing some 1-2" mesh will work. See the red strip in pix to see where I would cut.
Old 07-27-2012, 06:01 PM   #10
jkk
Rewards Points: 233
Back to this project ...
I've added another picture to help folks 'see' what I'm trying to do.
I'm trying to get air into the attic so the ridge vent works properly. My dilemma: what's the simplest, best way to cut/modify this blocking to get air into this attic?
Any suggestions?
Can I mount a window A/C into the wall, exhausting to the attic? Greg2230 HVAC 2 06-01-2010 08:56 PM
Frost in the Attic 295yards General DIY Discussions 13 12-07-2009 04:27 PM
Open Bean no Attic Bath Vent cdrusds HVAC 0 10-08-2009 03:46 PM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
Best way to open up attic space? bpchevyguy Building & Construction 7 07-03-2008 06:19 AM
