Renovating Basement And Insulation..gut Job Or Keeper.. - Insulation - DIY Chatroom Home Improvement Forum
Old 02-01-2014, 11:48 PM   #1
mcu
Renovating basement and insulation..gut job or keeper..
I recently bought a house and started renovating the basement. By removing a divisionw all, that ran across the exterior walls, I was able to see how it is insulated. 2x4 framing, Fibreglass insulation (not insulated to the floor....only the top six feet of a eight foot ceiling height) with the white wrap on one side and vapor barrier on on other side before the drywall. Half the exterior wall is framed about 1/2" gap from foundation to framing and other half has 4" (could of been less than 2") gap because of plumbing. So far I have only been able to see the foundation wall with the 4" gap and I do see condensation/ice....it's -20 here in Quebec this's week. I also noticed black stains....which at first thought was mould but not convinced yet. Ok now to the point
1. How can I test if the stains are mould and not tar paper or sheeting stains? I can pretty much wipe it off just by touching it. Would mould smell? I have no smell of mould in the basement, humidity is at 38%which is the same as the rest of the house.
2. As for the condensation....I think the issue is that since there is a 4" gap, the heat from the joists of the top floor actually goes behind the framed exterior wall and onto the foundation wall. Does this make sense or it is not the cause?
Now obviously for me, the easiest to do is leave basement as is, as I expected to do andjust finish the rest like floor, paint, etc. but I have children and want to make it as comfy as possible.
Would you guys rip off everything to see what is going on and fix the joist issue? Will I get much benefit to insulating the bottom 2' of the wall? I have 170' of exterior wall....so it won't be cheap to gut, install 2" eps, reframe and then fibreglass insulation, drywall, etc. need some help and opinions here
mcu is offline   Reply With Quote
Old 02-02-2014, 08:00 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,002
You going to keep and be living in the home for a while? If so, gut it and insulate it properly.
Old 02-02-2014, 08:05 AM   #3
mcu
No clue if we will stay here for long. We overdid it on the last house then sold it because we got a good offer
Any comments or suggestions on my other questions? Is the air in the joist going behind the wall the issue with condensation or is condensation really normal in -20 winters?
Old 02-02-2014, 08:26 AM   #4
You can contact a local lab and have the black staining tested for mold and type. Likely answer is that it is mold when you have -20 temps and 38% RH.
It is unlikely that moist air from the living space above is coming down, through the finished flooring, sup-floor, etc. to get into the the wall.
The conditioned air, shared by the entire home, is certainly getting around that wall assembly in the basement and getting to the condensing and cold wall.
Old 02-02-2014, 08:55 AM   #5
mcu
I have a humidification/dehumidification system with my central heat and maintain it at 35-40% for my hardwood floors through out the house. It is 38% at this minute with +1C outside temp and 20c inside temp.
Is there any DIY test you guys know of to test if mold or not? If it was mould wouldn't I have a musty smell or some types don't smell?
Old 02-02-2014, 12:34 PM   #6
Rewards Points: 153
Just lost a long post on this, so I'll make it short. Plan on trenching the top and bottom of the wall, pulling out the fiberglass insulation through the trench, inspecting the wall for water intrusion, fixing any intrusion problems, and then having it blown with rock wool.
The black streaks are most likely from air circulating across moist areas - particles in the air stick to moist surfaces, causing black streaks. I think that's what you're seeing.
There is no DIY mold test I'm aware of.
Find an insulating contractor that blows in rock wool, show him what you're dealing with, explain what you plan to do with trenching the walls and pulling out the fiberglass and get a quote. Practices vary by climate / location, so he may say that would be a no-go. You may have to gut it.
eandjsdad is offline   Reply With Quote
Old 02-02-2014, 06:24 PM   #7
Registered User
Rewards Points: 5,466
http://www.google.com/url?sa=t&rct=j...YQLG5n18RR0vdA
http://www.buildingscience.com/docum...ts?full_view=1
Gary
Old 02-02-2014, 07:15 PM   #8
Rewards Points: 153
CA practice tends to substitute Roxul for foam board, and there's more use of rock wool batts and blown in. All of those are moisture tolerant, fire proof, and don't provide material for mold growth. Dense pack rock wool air seals equivalently to any other dense pack.
Old 02-02-2014, 08:06 PM   #9
Registered User
Cellulose will work for the OP's location, pp. 60; http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja
Gary
Old 02-06-2014, 09:29 PM   #10
mcu
Opened up the wall to clean up mold/stains. Still debating weather to redo everything and re insulate. Currently r-13 and if I redo with 2" xps and then the batt, I will be up to r-23. The difference between the two in energy loss annually is 8 Mmbtu. I have no idea how to calculate how much that would save me per year. I figure it will cost between 5-6k in material to redo the entire basement. Trying to see if worth it and when I will be back into my money.
Any ideas?
Old 02-07-2014, 07:10 AM   #11
There are calculators out there that attempt to project fuel savings based on fuel types and R-Values.
Search around for one and see if you can get some cursory calculations on it.
You won't make your money back in 1 year but you might be surprised by the projections.
Old 02-07-2014, 07:42 AM   #12
mcu
I am using electricity. I found one for oil but they did not include electricity. Will keep looking, but it won't be something like 10-15 years?
Old 02-07-2014, 08:21 AM   #13
With electricity, in that region, it is going to be shorter.
Electricity is the worst way to heat and the most expensive per BTU.
Old 02-07-2014, 01:04 PM   #14
Registered User
Any ideas?
Compare Fig. 2 and Table 5, and Fig. 5; http://www.google.com/url?sa=t&rct=j...7c2C4A&cad=rja
And; http://www.quadlock.com/technical_li...Insulation.pdf
Your basement air is getting to the cold concrete wall past/around the insulation; starting on pp. 25;http://www.google.com/url?sa=t&rct=j...NBXd7F4za_-LyQ
Gary
Insulation in basement ceiling for soundproofing -- will basement be too cold? jmai14 HVAC 3 11-16-2013 10:04 AM
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 10:09 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
