Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 11-30-2012, 09:51 AM   #1
removing PL premium on block foundation
Hi i would to know how i could remove the PL adhesive that i have on the concrete block foundation. I removed som old foam that was on the bsement walls when we moved into our home to look for possible leaks when we moved into our home.
There is still small pieces of foam stuck to the PL where it it was used, i can remove the foam but the PL is still stuck to the walls. I would like to put new rigid foam board on the walls, and would like to put it on an even surface.
any suggestions, my only idea is using a grinder to remove it from the blocks.
chillz911 is offline   Reply With Quote
Old 11-30-2012, 10:28 AM   #2
Not going to be easy. I would not use a grinder, I believe it will just gum up.
A chisle or my ossilating saw with the blade with no teeth has worked for me.
Old 12-04-2012, 11:44 PM   #3
Maybe you could soften the stuff w/ xylene, toluene, or acetone. Wear gloves, as they will diffuse into your skin in a heartbeat. (Hey; get the PL good and saturated w/ one of those, then light it! )
Old 12-05-2012, 08:26 AM   #4
Exterior Construction
Windows on Wash's Avatar
Chisel if it is brittle enough.
Concrete reinforced block foundation repair questions CCHanna05 Building & Construction 2 07-06-2010 04:57 PM
White powder on block foundation walls. lscott Building & Construction 2 05-18-2010 09:32 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
Venting dryer through cinder block foundation wall jayp Building & Construction 10 04-08-2009 07:18 AM
Free standing block wall foundation 3DPiper Building & Construction 4 10-19-2006 09:42 PM
