-   Insulation (http://www.diychatroom.com/f103/)
-   -   removing PL premium on block foundation (http://www.diychatroom.com/f103/removing-pl-premium-block-foundation-165152/)
chillz911 11-30-2012 08:51 AM
Hi i would to know how i could remove the PL adhesive that i have on the concrete block foundation. I removed som old foam that was on the bsement walls when we moved into our home to look for possible leaks when we moved into our home.
There is still small pieces of foam stuck to the PL where it it was used, i can remove the foam but the PL is still stuck to the walls. I would like to put new rigid foam board on the walls, and would like to put it on an even surface.
any suggestions, my only idea is using a grinder to remove it from the blocks.
joecaption 11-30-2012 09:28 AM
Not going to be easy. I would not use a grinder, I believe it will just gum up.
A chisle or my ossilating saw with the blade with no teeth has worked for me.
jklingel 12-04-2012 10:44 PM
Maybe you could soften the stuff w/ xylene, toluene, or acetone. Wear gloves, as they will diffuse into your skin in a heartbeat. (Hey; get the PL good and saturated w/ one of those, then light it! :laughing:)
Windows on Wash 12-05-2012 07:26 AM
Chisel if it is brittle enough.
