Removing Old Fiberglass Insulation Around My Pipes - Insulation - DIY Chatroom Home Improvement Forum
Old 04-20-2012, 03:22 PM   #1
Removing old fiberglass insulation around my pipes
First time poster! hope you guys can help!
Since there have been sort of health issues regarding removal of old fiberglass insulation.What is the best way to remove it? Should i get a professional to do it?
Thx
ROSSANO is offline   Reply With Quote
Old 04-20-2012, 03:37 PM   #2
Pure Genius
Rewards Points: 150
Fiberglass or asbestus? If fiberglass than wear a respirator
Dierte is offline   Reply With Quote
Old 04-20-2012, 03:43 PM   #3
Originally Posted by dierte View Post
fiberglass or asbestus? If fiberglass than wear a respirator
here is a pic
Old 04-20-2012, 04:29 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Wear a respirator and some gloves. Put the stuff into some heavy contractor type garbage bags and tie them shut. You will be fine. Paying somebody to do this will cost you big $. Reinsulate with the proper insulation for the type of pipe.
Old 04-21-2012, 05:10 PM   #5
Thank you!
when you say use the proper insulation, which one do you suggest?
Thx again!
Old 04-21-2012, 11:21 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,112
They make pipe wraps.
Just figure out what size the pipe and there are different options.
The Following User Says Thank You to Windows on Wash For This Useful Post:
ROSSANO (04-22-2012)
Old 04-22-2012, 07:23 AM   #7
Originally Posted by ROSSANO View Post
Thank you!
Thx again!
It depends on what you are insulating. Domestic water lnes can use foam, heating should use preformed fiberglass. Refrigeration lines should use Armaflex.
The Following 2 Users Say Thank You to Maintenance 6 For This Useful Post:
Ravenworks (04-22-2012), ROSSANO (04-22-2012)
Old 04-22-2012, 10:33 AM   #8
Thank you
Old 04-22-2012, 10:34 AM   #9
Thank you
Old 04-23-2012, 11:52 AM   #10
Just a DIY guy
heating should use preformed fiberglass. .
I assume you are talking about heating ducts. Is there really such a thing as preformed fiberglass for that?
I know there are fiberglass wraps like these
http://www.homedepot.com/Building-Ma...ProductDisplay
You use this kind of tape to secure the plastic covering
http://www.homedepot.com/Building-Materials-Heating-Venting-Cooling-Ducts-Duct-Tape/h_d1/N-5yc1vZariy/R-100575721/h_d2/ProductDisplay
M3 Pete is offline   Reply With Quote
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 09:49 PM
Steam Pipe insulation. Any gain for insulating return pipes? slowjo HVAC 17 02-19-2012 09:53 AM
Unvented Attic with fiberglass insulation hartkem Insulation 16 12-21-2011 11:42 PM
Removing fiberglass batts without fibers all over house darlingm Insulation 7 09-10-2011 10:47 AM
Is fiberglass insulation safe for us with dishwasher? jen78fl General DIY Discussions 10 01-31-2008 06:51 PM
