-   Insulation (http://www.diychatroom.com/f103/)
-   -   Removing old fiberglass insulation around my pipes (http://www.diychatroom.com/f103/removing-old-fiberglass-insulation-around-my-pipes-140875/)
ROSSANO 04-20-2012 02:22 PM
First time poster! hope you guys can help!
Since there have been sort of health issues regarding removal of old fiberglass insulation.What is the best way to remove it? Should i get a professional to do it?
Thx
Dierte 04-20-2012 02:37 PM
Fiberglass or asbestus? If fiberglass than wear a respirator
ROSSANO 04-20-2012 02:43 PM
1 Attachment(s)
Attachment 49354
Originally Posted by dierte (Post 903175)
fiberglass or asbestus? If fiberglass than wear a respirator
here is a pic
Maintenance 6 04-20-2012 03:29 PM
Wear a respirator and some gloves. Put the stuff into some heavy contractor type garbage bags and tie them shut. You will be fine. Paying somebody to do this will cost you big $. Reinsulate with the proper insulation for the type of pipe.
ROSSANO 04-21-2012 04:10 PM
Thank you!
when you say use the proper insulation, which one do you suggest?
Thx again!
Windows on Wash 04-21-2012 10:21 PM
They make pipe wraps.
Just figure out what size the pipe and there are different options.
Maintenance 6 04-22-2012 06:23 AM
Originally Posted by ROSSANO (Post 903951)
Thank you!
Thx again!
It depends on what you are insulating. Domestic water lnes can use foam, heating should use preformed fiberglass. Refrigeration lines should use Armaflex.
ROSSANO 04-22-2012 09:33 AM
Thank you
ROSSANO 04-22-2012 09:34 AM
Thank you
M3 Pete 04-23-2012 10:52 AM
heating should use preformed fiberglass. .
I assume you are talking about heating ducts. Is there really such a thing as preformed fiberglass for that?
I know there are fiberglass wraps like these
http://www.homedepot.com/Building-Ma...ProductDisplay
You use this kind of tape to secure the plastic covering
http://www.homedepot.com/Building-Materials-Heating-Venting-Cooling-Ducts-Duct-Tape/h_d1/N-5yc1vZariy/R-100575721/h_d2/ProductDisplay
