Removing Old Blown-in Insulation In Attic? - Insulation - DIY Chatroom Home Improvement Forum
Old 04-04-2012, 01:27 PM   #1
Rewards Points: 212
Removing old blown-in insulation in attic?
I've seen/read about a machine that basically vacuums out the old blown in insulation. So I assume its some type of very big vacuum. I have a couple of questions:
1) Can re-use the insulation, correct? Is it not recommended?
2) Where do I find someone that does this? Would most any insulation install company do this?
3) What is the machine called and can I rent it somewhere?
imola ghost is offline   Reply With Quote
Old 04-05-2012, 08:45 AM   #2
Rewards Points: 240
why do you want to remove it ?
Fix'n it is offline   Reply With Quote
Old 04-05-2012, 08:50 AM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
1) NOT recommended, nor possible I believe.
2)Google. Most should be able to remove and replace with new.
3) Don't know the the name,don't think you can for removal. You can rent to install thou.
sublime2 is offline   Reply With Quote
Old 04-05-2012, 10:09 AM   #4
Missouri Bound's Avatar
Yeah, good question. If it's in the way, move it, if it's not enough, add to it. Unless it is damaged by mold or infestation leave it be.
Do you want it your way or the right way?
Old 04-05-2012, 10:14 AM   #5
Rewards Points: 212
I can understand but what I wanted to do was wire up the house for whole house audio and while I was there caulk and seal up all light fixtures and holes that I see. The best way that I can see to do this thoroughly is to remove old (since I'm going to replace with spray foam and blown in cellulose) and that would allow me to move around freely and completely seal up the house.
Old 04-05-2012, 10:32 AM   #6
Rewards Points: 240
i am in the same boat. except i have old batt insulation. i was thinking about just just moving it to one or two areas and piling it up. as getting it out of the attic would be a BEAR.
Old 04-05-2012, 11:32 AM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Most insulation companies will have a vacuum or can recommend someone with one.
If you are doing a full re-wire and air sealing, it is nicer to have it all out and a blank canvas.
Old 04-05-2012, 11:48 AM   #8
Rewards Points: 212
That's what I'm doing.
Old 04-05-2012, 05:18 PM   #9
Just a DIY guy
Nicer yes, but what's the cost to replace it all?
I'm doing air sealing little by little under my R19 batts. Replacing all of them would cost about $1500, not including all the extra time to cut everything to fit. R30 would be about $2200. That buys a lot of gas and electricity.
Maybe the blown in is a lot cheaper?
M3 Pete is offline   Reply With Quote
Old 04-05-2012, 05:29 PM   #10
Blown in is cheaper and more effective for that matter. Win...Win
Old 04-05-2012, 08:54 PM   #11
Rewards Points: 212
I'm going to do my bonus room with spray foam around all four outer walls. Then once I get the house wired up, sealed up around all the light fixtures and what not...I blow in about 36 inches of blown in insulation.
Old 04-05-2012, 10:21 PM   #12
I wonder if you could use a dust collector to remove it? Not sure about reusing it but then again why not? It's YOUR house...
Justgaff is offline   Reply With Quote
removing old attick blown in insulation acrazygy@yahoo. Insulation 1 02-16-2012 06:54 PM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 07:08 PM
Attic Insulation tim1218 Insulation 4 09-07-2011 10:18 AM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
removing blown insulation jestersma Remodeling 8 05-30-2006 02:47 PM
