Removing Insulation From Soffitt - Insulation - DIY Chatroom Home Improvement Forum
Old 05-03-2012, 02:32 PM   #1
removing insulation from soffitt
While installing a new bathroom vent/fan in the master bath, with the outlet down through the soffitt, I found that the previous owner had blown insulation onto the soffitt. The house has vaulted ceilings, and I can't get to that part of the attic to remove the insulation manually. The soffitts are vinyl covered steel that are nailed on the facia and slid into a u-shaped channel on the siding.
Any ideas how to remove the insulation without damaging or removing the existing soffitt?
drdog54 is offline   Reply With Quote
Old 05-06-2012, 06:07 PM   #2
Checking things out
I haven't tried it, but have thought through how I would clear insulation from the soffit if I needed to and think that aiming a leaf blower up to the soffit vents from beneath would probably be sufficient to force out any insulation that had unintentionally collected there...
Hope that helps.
-Mason
masonbrown is offline   Reply With Quote
Removing old damaged insulation Megsmom88 Insulation 9 04-11-2012 07:52 PM
Removing old blown-in insulation in attic? imola ghost Insulation 11 04-05-2012 10:21 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
2x4 Exterior Wall Insulation stubits Building & Construction 4 03-19-2009 07:03 AM
