#1 |
Remove old rockwool before new insulation?
I am living in a house built in mid-80's in Seattle, Washington (zone 4), I'm planning to install more insulation in the attic.
I believe the attic has rockwool? insulation around 3-4 inches high and there's no vapour barrier beneath the existing insulation, just resting on the ceiling drywall. Should I have someone remove the old rockwool insulation and start all over or just put the new unfaced insulation roll on top of the existing rockwool?
A picture is worth a thousand words. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#2 |
Exterior Construction
That is most likely cellulose and not rockwool.
No need to remove it, however, you must-must-must air seal prior to installing more insulation. That flue (assuming that is) pipe also need to be clearanced from the insulation and should not be in direct contact with the insulation. Isolate out with fire rated drywall or sheet metal.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Crusty Old Dude
Yep, that is cellulose. Rockwool is what we used to call the "Brown Death". Nasty stuff it is. Is good for firestop and insulating though.
All the best to you and yours, Tom |
#4 |
Thank you for identifying the cellulose! No removing the material so no vapour barrier is needed or is it better to have that ?
Is it better to use blown cellulose or the fiberglass rolls we get from big box stores ?
#5 |
Just lay unfaced fiberglass over it laying in the oposite direction.
#6 |
Not a big fan of cellulose, but seeing as how you already have it, would it make more sense to just add more cellulose than try to put something over or in place of it?
I think they make big vacuums just for removing it. |
#7 | ||
Remove old rockwool before new insulation?Quote:
Cellulose is a far better insulated than its blown in fiberglass counterpart. Batt fiberglass (when high density) is okay but more labor intensive to install and requires the surface to be uniform and level for proper alignment and to prevent any air movement between sections. Quote:
What is it that you are not a fan of with cellulose? While okay, conditional on using a high density batt, this application is about 2X the work to do properly than blowing in cellulose.
#8 |
Remove old rockwool before new insulation? |
#9 | |
Good cellulose is well know for settling out nicely an filling voids very well.
| Display Modes | |
| Attic insulation problem | Dan77 | Building & Construction | 7 | 12-22-2010 03:10 PM |
| yet one more insulation question | Mike in Arkansas | General Discussion | 6 | 11-11-2010 10:47 PM |
| Adding insulation and storage to Cape Cod Side Attic | turin39789 | General Discussion | 5 | 11-08-2010 11:50 AM |
| Adding attic insulation | pomelo | Building & Construction | 3 | 10-22-2009 06:19 PM |
| Installing new insulation in my basement and removing the old moldy insulation. | Fixitgeorge | Remodeling | 3 | 10-17-2006 09:33 PM |
