Remove Old Balsam Wool Insulation? - Insulation - DIY Chatroom Home Improvement Forum
Old 03-28-2011, 09:54 AM   #1
Rewards Points: 172
Remove old balsam wool insulation?
Hello:
I have an old house with the balsam wool insulation in the attic. It looks to be double sided with the black facing and about an inch thick (brown inside). I wanted to reinsulate the attic. Can I insulate over this old stuff or should I remove it first and then insulate? If I inulate over it, do I use insulation without the facing?
zephed666 is offline   Reply With Quote
Old 03-30-2011, 06:36 PM   #2
Registered User
Rewards Points: 5,516
Picture would help....
Where are you located?
Gary
Old 03-31-2011, 08:36 AM   #3
Rewards Points: 172
Gary
Long Island NY. I'll try to get a picture up tonight. My plan was to remove it all and put in new R60 insulation, but if I don't have to, why bother.
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Attic Insulation paige2 General DIY Discussions 21 03-16-2011 10:35 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
We need more venting and insulation Scott Stevens Roofing/Siding 5 10-15-2010 12:55 PM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
