Remove Or Not ? - Insulation - DIY Chatroom Home Improvement Forum
Old 04-05-2012, 11:13 AM   #1
Rewards Points: 222
remove or not ?
see pic. i want to insulate my rim joists. they have a brick fireblocking(?) between them. and there is not sill plate, i can see the holes in the tops of the block wall.
should i take out the bricks, or just go over them ? there is about 1" of back space.
thanx
Fix'n it is offline   Reply With Quote
Old 04-05-2012, 12:31 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,900
Go over them.
I would not remove them.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Fix'n it (04-05-2012)
Old 04-05-2012, 12:49 PM   #3
Rewards Points: 222
really !? wow, thats great. now, what do i go over them with ?
Old 04-05-2012, 01:10 PM   #4
Rewards Points: 1,092
I'd glue in rigid foam, and seal any gaps w/ Great Stuff. If you cut the foam to be forced in, you'll be fine. Keep an eye on the floor joists, as you will be reducing any drying to the inside that has been happening. Make sure they are not getting wet (probably won't). Do whatever you can to keep the outside of that area dry. Why are the joists so dark?
The Following 2 Users Say Thank You to jklingel For This Useful Post:
Fix'n it (04-05-2012), Windows on Wash (04-05-2012)
Old 04-05-2012, 01:22 PM   #5
Ravenworks's Avatar
Ridged foam board.
Ravenworks is offline   Reply With Quote
Old 04-05-2012, 01:30 PM   #6
+1
Great advice jk!
Old 04-05-2012, 06:26 PM   #7
Rewards Points: 222
sounds very good to me
now, i have never worked with that foam board. what is a good way to cut it ? i have a stihl chain saw
obviously, when checking the joists for moisture, i cannot see behind the foam. if the dry was not happening, would they be wet where i can see them ?
the timbers are dark, but not as dark as they look in the pic. but, the house is old, all the boards in here are dark.
Old 04-05-2012, 08:02 PM   #8
Originally Posted by Fix'n it View Post
what is a good way to cut it ? i have a stihl chain saw That will get dull to fast. Use a hand saw, or score deeply w/ a utility knife and snap it. I never get nice snaps, so if the specs are tight I'd rather saw it. Saw it at your neighbor's, though. His kids can play in all the foam chips lying about.
...would they be wet where i can see them ? *I would think that if they are wet at the ends, you'll see they are damp against the foam.
see after bullets.
The Following User Says Thank You to jklingel For This Useful Post:
Fix'n it (04-06-2012)
How do you remove a wood stove and bricks from living room? SimpleJack Remodeling 13 08-28-2011 02:26 PM
Wrong Sealant used on Unfinished Ceramic Tile... how to remove?! flipjarg Flooring 3 02-15-2010 10:09 PM
best way to remove areca palm root system Dus Landscaping & Lawn Care 0 01-23-2010 10:40 AM
Frigidaire/can't remove front water/ice dispenser tigerfan44 Appliances 0 12-17-2009 11:45 PM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing/Siding 3 07-02-2008 03:10 AM
