Remodeled ...walls - Insulation - DIY Chatroom Home Improvement Forum
Old 06-13-2014, 06:09 PM   #1
MarginallyQualified
Rewards Points: 2,464
remodeled ...walls
50+ year old brick veneer home with ZERO insulation.
I'm exposing about 40lf of exterior wall.
I want to add insulation.
My go to would be (R15) Roxul Batts
I've been told that I need to fir out the walls to fit thicker material.
It's a LOT of bother and expense I'd rather avoid.
So... what is (or should be) really required?
Thanks.
Old 06-13-2014, 06:56 PM   #2
Rewards Points: 14,300
Furring it out is the right way to do.
Only other way is to have it spray foams.
Old 06-13-2014, 07:55 PM   #3
MarginallyQualified
You're leaving out a few details; such as:
-what is the minimum R value to be achieved?
-which code is that?
-is foam able to do that in 3 1/2" (vs the fir etc)
Thanks.
Old 06-13-2014, 10:14 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
R15 and air sealing n the sidewalls will be more than enough. You won't see an ROA on furring out the walls... and that's assuming that your attic, basement, etc are taken care of.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 06-14-2014, 08:33 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
+1 to Homesealed comments.
The brick provides pretty good thermal mass and air sealing the walls prior to installation of batts would be sufficient in my opinion.
Guess that the exterior wall does have sheathing from the picture.
Fix the attic and seal up the top plates too.
Old 06-14-2014, 12:22 PM   #6
MarginallyQualified
Thanks for the replies: R15 Roxul it is.
Yes... the framing has some sheathing on it,
the attic is (or will be R30 at least,
and the basement is getting 2" XPS on walls (and at band joist)
in addition to more R15 ROXUL in the framed 2x4 wall.
The money I'm saving on T&M to rip the firring strips...
will buy a couple of steak dinners.
Looking for confirmation these walls are not load-bearing walls jmai14 Remodeling 2 11-09-2013 09:28 PM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 01:20 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 04:12 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
