-   Insulation (http://www.diychatroom.com/f103/)
-   -   "Refletix" around Incoming Water Line OK? (http://www.diychatroom.com/f103/refletix-around-incoming-water-line-ok-163005/)
Bhava 11-11-2012 07:44 PM
The water line coming into my cabin is made of copper. The exposed section (from ground to cabin) is about 3 feet. The line froze last year at about -20C. I was told that using "Reflectix" would help to protect it. I have a piece that is about 10'x 10', and was thinking about wrapping it around the pipe. Would that work, as a last minute solution?
Thanks for any help!
burnt03 11-11-2012 08:23 PM
It might slow it down, but it'll still freeze eventually.
Consider wrapping heat-tape around the exposed section of pipe and then insulating around that. http://www.homedepot.ca/product/15-f...g-cable/909328
If all else fails, just keep the water running all the time.
Windows on Wash 11-11-2012 08:44 PM
Needs to be insulated.
Bhava 11-11-2012 08:53 PM
My situation is that my cabin is off the grid. I use a generator and solar panels to charge the battery banks, then an inverter, but only part time.
The reason I'm thinking about the reflectix is, if the pipe does freeze, I can access it if need be. Originally, I was thinking about building a box around it and using expanding foam to fill in the space, but I'm concerned about its effectiveness.
Plus, if I have to take off the foam, it will be a major trip. So, for this reason, reflectix seemed to be a good alternative. I just don't know enough about this stuff, and winter is already starting to set in.
burnt03 11-11-2012 10:01 PM
No matter how you insulate it, if it gets down to -20 without heat on/around it, it's going to freeze. But it's worth a try.
Unless you keep the water running all the time.... but if you're off the grid, I'm guessing you're on a well (powered by the generator), so that's not an option either.....
Sorry I couldn't help!
Windows on Wash 11-12-2012 07:00 AM
+1
If you are gone for long periods of time, a heat tape is your only option. No matter the insulation value, it will freeze eventually. Either some sort of circulation pump or a heat trace tape will keep it unfrozen.
