Reflective Duct Wrap Vs Fiberglass Wrap - Insulation - DIY Chatroom Home Improvement Forum
Old 12-05-2012, 12:02 AM   #1
Reflective Duct Wrap vs Fiberglass Wrap
Hi,
I just bought my first home in August and I've decided to try and do most of my home repairs myself. So I'll be here quite a bit asking for advice.
My house has the hvac duct work in the basement void of any insulation. It's looks like there is some kind of brown paper material pasted and wrapped all around the ducts, which is painted white (I think it's paint). Also, the heat doesn't feel as warm as I think it should be once it enters the rooms. As a result, I'd like to insulate the ducts hoping to get better heating for my home.
My question is would reflective duct wrap or fiberglass wrap be more effective in getting better heating for the home, or would it be the same? Thanks.
dliu138 is offline   Reply With Quote
Old 12-05-2012, 08:25 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,820
No need to insulate ductwork if it is inside the conditioned spaces.
Seal up all the seams but that is all that you need to do.
Old 12-05-2012, 08:40 AM   #3
Rewards Points: 13,270
How old is this house?
What your discribing sounds like it just might be asbestos insulation that's been wraped to seal it.
Got a picture?
Old 12-05-2012, 08:49 AM   #4
Got a picture?
Good catch Joe.
If it is TSI (Thermal Systems Insulation), do not touch it.
It needs to be abated by a qualified contractor and is very dangerous.
Old 12-05-2012, 01:25 PM   #5
The house was built in 1959. Here are a couple pics. I'm feeling nervous now.
Reflective Duct Wrap vs Fiberglass Wrap-2012-12-05-10.18.19.jpg   Reflective Duct Wrap vs Fiberglass Wrap-2012-12-05-10.18.36-1-.jpg   Reflective Duct Wrap vs Fiberglass Wrap-2012-12-05-10.19.13.jpg   Reflective Duct Wrap vs Fiberglass Wrap-2012-12-05-10.19.46.jpg
Old 12-05-2012, 03:06 PM   #6
Nothing to be nervous about as long as it is encapsulated and in good shape.
Old 12-05-2012, 06:49 PM   #7
Does it appear to be TSI? Do you think I should insulate this or leave it alone?
Old 12-06-2012, 08:40 AM   #8
Tough to say but if you are concerned, get it tested.
Regardless, I would not disturb it in the meantime.
Old 12-06-2012, 09:04 PM   #9
Thanks for the help.
Old 12-07-2012, 11:21 PM   #10
get it tested but it looks like mastic and paint. Looks way to thin to be TSI, however it may mean a poor contractor removed it and painted it to make it look finished instead of doing it right.
If it is not TSI, then use fiberglass, I would use denim, insulation over reflective. Ensure Vapor barrier is the right direction. Reflective requires air space between the meal duct and the insulation to get full R-value, not to mention costs more.
rebelranger is offline   Reply With Quote
Asbestos Duct Wrap jvc120er HVAC 16 02-19-2012 06:19 PM
Is this fiberglass insulation safe (touching heating duct)? nutlog Insulation 6 01-27-2012 08:18 PM
Using flex duct for return. lakeresident HVAC 3 11-14-2011 10:56 AM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 09:28 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
