Reduce Noise From Outdoor Radon Fan? - Insulation - DIY Chatroom Home Improvement Forum
Old 05-15-2015, 06:48 PM   #1
Rewards Points: 55
Reduce noise from outdoor radon fan?
[Hope this is the right forum for this question...]
Our outdoor radon fan (see photo) emits a hum. Not too loud. But I would like to reduce the noise even further. Any ideas on how to do this? Is there any type of wrap suitable for outdoor installation that I can use? Some other product? Something I can make?
Thank you.
goshenplumber is offline   Reply With Quote
Old 05-16-2015, 06:16 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,786
Not much else to do to those.
Its coupled on both ends by a rubber ferco so there shouldn't be any vibration there.
Make sure the PVC isn't touching the fan body and make sure the fan is in good shape. Worn out bearings and out of spec tolerances will net a vibration out of the fan.
Old 05-16-2015, 10:45 AM   #3
Registered User
Rewards Points: 5,520
Check nameplate to see if you can wrap it with insulation or build insulated box around it, at the Fernco...
Gary
Old 05-16-2015, 01:25 PM   #4
Rewards Points: 55
What type of insulation for outside?
Gary
Gary -- I was thinking of wrapping with insulation, BUT what type of insulation can be used outside? Bubble wrap? Something else????
Old 05-17-2015, 05:35 AM   #5
Rewards Points: 865
My radon fan is outside under a deck. We can't hear it at all. To tell if my system is running I have to put ear to exhaust pipe to hear the rush of air. If your fan is older I would consider buying a new one.
ddsrph is offline   Reply With Quote
Old 05-17-2015, 01:39 PM   #6
Registered User
Some reading is due you; http://www.wpb-radon.com/Radon_fan_n...ml#quiet%20fan
Might also enjoy; http://www.wpb-radon.com/pdf/Radon%2...ation%2004.pdf
Gary
Carpet underlay to reduce noise silvercity Flooring 2 04-19-2013 02:23 PM
Will the noise reduce if installiing drywall on a glassless window? baby327nd Windows and Doors 2 03-21-2011 08:55 PM
Reduce noise of air handler through ceiling bigburb HVAC 2 09-13-2010 08:38 PM
Would a drop ceiling reduce percussive walking noise from neibor above? fredonian Building & Construction 8 05-19-2009 03:23 PM
