Re-thinking My Basement Wall Insulation System - Insulation - DIY Chatroom Home Improvement Forum
Old 09-30-2011, 09:46 AM   #1
Re-thinking my basement wall insulation system
Would like some opinions from the forum:
I am finishing my basement and the first is insulating the exterior foundation (poured) wall. My original plan was glue 1" rigid foam insulation to the wall, then stud frame the wall over that, then insulate the wall cavities with r-13 fiberglass. like this pic.
Now, I'm thinking of simplifying things. Why not glue 2" rigid foam to the wall and attach with firring strips. Then attach the drywall to the firring strips. I'd use a p.t. sill plate and top plate.
One drawback to this method is difficulty mounting any heavy objects to the wall I. E. a flat panel tv. Electrical boxes present a problem to.
Any input would be appreciated. Thanks.
1jumper is offline   Reply With Quote
Old 09-30-2011, 09:50 AM   #2
Rewards Points: 150
Dont reinvent the wheel. Use full studded walls. You be glad you did.
OhioHomeDoctor is offline   Reply With Quote
Old 09-30-2011, 12:05 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,112
+1
I prefer a full studded wall as well.
Old 09-30-2011, 01:29 PM   #4
Thanks for the replies. Anyone else?
Old 09-30-2011, 03:09 PM   #5
ccarlisle's Avatar
Well, that depends a bit on where you are because on the one hand you're looking at a wall assembly that has an R-value of about 7.5 (see later) and on the other you're looking at about R18. So, which one fits?You don't mention the need or not of a vapour retarder either, so I'll assume you're not dealing with cold winters.
But the better assembly for drywall-to-furring strips is the use of 1.5" of rigid foam boards, and 1.5" concrete screws - otherwise you'll be dealing with 2.5" screws over 2" rigid foam to get an R10...I don't like that configuration really. So, back to the 1.5" boards and screws.
But whether or not you need an extra R13, only your situation will really tell. In some parts, it's code to have a certain amount and therefore not really worth it to implement your own 'hybrid' assembly.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 09-30-2011, 04:37 PM   #6
AGWhitehouse's Avatar
I'd recommend 2" XPS foam glued to the conc. wall with taped seams and a 2x4 framed wall over the top. It'll give you the vapor control and the freedom for electrical and wall mounting.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 09-30-2011, 09:24 PM   #7
Thanks for the advice. I live in mid-Michigan so winters are cold. I guess I'm going with the original stud framing route. It'll keep things easier even if it isn't quite as simple as firring strips and 2"foam.
Old 10-05-2011, 09:18 PM   #8
Rewards Points: 410
Get the large caulk gun as the pl is lots cheaper that way and don't be stingy with the glue.
Any air that can get around from the foam/concrete wall and you've lost
the advantage of putting it there in the first place.
I put a heavy bead in the groove joint vs using tape.
High Gear is offline   Reply With Quote
Old 10-05-2011, 09:48 PM   #9
concretemasonry's Avatar
Rewards Points: 2,578
Don't over-think the concept of insulating a basement. It really isn't worth it in many situations.
The exterior Soil temperature is extremely stable and does not reflect the exterior AIR temperature. The cool soil is actually a benefit on an annual basis. The frost depth is a figment of code writers imagination.
When you are dealing with theoretical R-values of lightweight insulation you are only looking at the theoretical short term laboratory values over a hour ot so for the insualation "material" in an ideal situation (dry) and not the effects of the thermal short circuiting of any studs. Granted, XPS is a far better value because it can be a complete thermal break.
A basement is actually a semi-conditioned space and if it has air returns, there are summer benefits from the temperature heat sink repersented by the exterior soil.
Dick
concretemasonry is offline   Reply With Quote
Old 10-24-2011, 07:18 PM   #10
I thought from reading In these forums that a vapor barrier is undesired in a basement. I've read a few places that it "needs to breathe."
daphillenium is offline   Reply With Quote
Old 10-26-2011, 11:28 AM   #11
Rewards Points: 640
everything I've read contradicts itself it seems like....
seems like you need at least one direction for it to breath... either inward or outward... but then houses now days can be ICF which is insulated on both sides with 2" EPS but that isn't a complete vapor barrior like 2" of XPS is...
I just wouldn't put XPS on the inside if you have it on the outside and vice versa... anyone else think that is a good idea?
BlueBSH is offline   Reply With Quote
Old 10-26-2011, 02:52 PM   #12
If you have 2" XPS or greater on the outside, then 1" max. XPS on the inside and vice versa. 2" of XPS is a class II vapor retarder, while 1" is a class III. EPS foam remains a class III retarder for thicknesses beyond most common applications.
Old 10-26-2011, 02:57 PM   #13
Yes, wall systems need to breath. The problem for basement spaces is that the breathing only really happens to the interior because the exterior is underground and usually moisture laden. The reason it's undesireable to have a vapor barrier on the inteiror side of a basement wall system is that if moisture does drive in, a barrier will block and trap it, leaving it no-where to go. This trapped moisture can lead to structural decay of the wall systems over the course of it's functional lifetime. Having a vapor retarder (class II at most) directly against the wall will provide a membrane that slows the transfer of moisture during wet weather to prevent water-based damages, but will allow it to dry to the interior during dry weather conditions.
Old 10-26-2011, 03:10 PM   #14
Rewards Points: 640
what class would kraft faced insulation be in? when our house was built they did part of the basement with only R-13 kraft faced no XPS or foam inside or out
Old 10-26-2011, 03:54 PM   #15
Rewards Points: 93
I believe it's Class II.
leungw is offline   Reply With Quote
Finishing my basement: wall insulation? 1jumper Insulation 6 09-15-2011 11:29 AM
Basement Insulation Question gilbo125 Building & Construction 9 02-01-2011 05:13 AM
Adding to existing wall insulation in basement? Pjartsmile Remodeling 2 09-19-2010 02:06 PM
Basement wall insulation dandw12786 Building & Construction 4 07-15-2010 02:11 PM
Need unbiased help on finishing basement - Dry wall or panel system? mmr1234 Building & Construction 6 08-29-2009 11:30 AM
