Ramset 2 Inch Foam Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 01-05-2012, 06:08 PM   #1
Ramset 2 inch foam insulation
There is a way of using a ramset to install 2inch foam insulataion to concrete. Where do I find this gun and the fasteners?
edgecomb53 is offline   Reply With Quote
Old 01-06-2012, 12:15 AM   #2
43 years in construction
Arkitexas's Avatar
Ramset will blow a hole through the foam insulation. I assume this is a concrete wall you are asking about. There are fasteners called "stick-clips". They are a metal plate with a welded spike. The plates are adhered to the wall with epoxy and the insulation is pushed to the wall and the stick-clips impale the insulation, sticking out about 1 or 2 inches. The attachment is completed with a plastic or metal disk pushed down the protruding spike which resists backing off (sorta like an oversized tinnerman nut).
http://www.midwestfasteners.com/prod...-fasteners.php
Rick
Arkitexas is offline   Reply With Quote
Vapor sealing with open cell foam insulation PerpetuallyRepairing Insulation 6 12-17-2011 09:16 PM
Home Energy Audit & Spray Foam Insulation sweets Insulation 7 09-08-2011 10:45 PM
Foam Insulation turbomangt Roofing/Siding 13 11-02-2010 09:44 PM
rigid foam insulation on interior itin1200 Building & Construction 24 10-17-2010 07:22 PM
Spray in foam insulation leted_82 Building & Construction 3 05-31-2007 10:14 AM
