Ramset will blow a hole through the foam insulation. I assume this is a concrete wall you are asking about. There are fasteners called "stick-clips". They are a metal plate with a welded spike. The plates are adhered to the wall with epoxy and the insulation is pushed to the wall and the stick-clips impale the insulation, sticking out about 1 or 2 inches. The attachment is completed with a plastic or metal disk pushed down the protruding spike which resists backing off (sorta like an oversized tinnerman nut).
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
