Rafters Insulation? - Insulation - DIY Chatroom Home Improvement Forum
Old 10-12-2012, 04:12 PM   #1
wood hobbyist
Rafters insulation?
Ok I'm getting ready to insulate my rafters in a attic playroom I'm finishing. I got my hands on enough "free" 4x8x3/4" foam insulation board to insulate all of the area between the rafters. My question to everyone is this enough insulation or will I have to add Insulation Batts also. So I have about 6-8" of space in the rafter channels to the edge where the sheet rock will go. I have already installed rafter vent baffles and have roof ridge vents for venting. I live in the Memphis area so our winters get as low as teen's and summers get into the 100's.
**corrrection** I got to inspect the foam insulation this weekend and found it to be in different thicknesses 4x8 sheets still, but my choice of 4", 8", and 10" THICK! Again its going in between the rafters not the floor joist.****and its FREE.
weberus3 is offline   Reply With Quote
Old 10-12-2012, 04:22 PM   #2
funfool's Avatar
Rewards Points: 534
not enough, but some is better then nothing. If it is free or cheap use it.
For best results blow it in, can rent a machine at Home depot and buy the bags of insulation.
Would not hurt to blow it over the foam later, but very little R-value in 3/4" foam, depending on the foam, is probably r-7 or less.
But still better then nothing.
funfool is offline   Reply With Quote
Old 10-12-2012, 04:31 PM   #3
Rewards Points: 13,732
http://www.energystar.gov/index.cfm?...sulation_table
The baffles are going to take up about 1-1/2" of the avalible space.
I at least add 2 X 2's to the rafters so I can at least add R-13.
Old 10-12-2012, 04:36 PM   #4
An old Tradesmen
Rewards Points: 7,370
Moved to Insulation forum.
Old 10-12-2012, 11:47 PM   #5
Registered User
Rewards Points: 5,516
Appears you are in Zone 4, requiring R-38 in ceilings; http://publicecodes.cyberregs.com/ic..._11_par002.htm
http://publicecodes.cyberregs.com/ic..._11_sec002.htm
Don't use cellulose in the cathedral areas. I would use Roxul, install full sheets on the rafters for one layer after filling cavities, if you have enough, then drywall. Or just some rips to cover the rafter edges to prevent thermal bridging, foam air-seal one layer of the cavity foam. ADA the drywall; http://www.buildingscience.com/docum...wall-approach/
Gary
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Foam Insulation in Rafters marine02ss Insulation 3 03-30-2012 03:38 PM
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
garage roof insulation between rafters denverman71 Building & Construction 1 10-21-2009 12:06 PM
Old home insulation woes nowwhatnapster Building & Construction 15 11-02-2008 11:59 PM
