Rafter Tail Ventilation Question - Insulation - DIY Chatroom Home Improvement Forum
Old 05-28-2014, 11:18 PM   #1
Rewards Points: 892
Rafter tail ventilation question
I have exposed rafter tails. I live in AZ.
My plan is to lock out the 2x4 spacers between the tails and put in vents. Not sure what concept to use. Regardless, how do I install the ventilation baffles with no soffits?
If I'm understanding the design of ventilation baffles, it covers the top plate and allows air to move up the roof from the soffits. Yet, if I have no soffits, how can I attach the baffle to the top plate if the top plate will be occupied by my 2x4 spacer?
Does that make sense?
Daugela is offline   Reply With Quote
Old 05-29-2014, 10:36 AM   #2
Rewards Points: 13,732
Considered enclosing the whole fascia and soffit area and using vinyl or aluminum vented soffits?
Instead of removing the 2 X 4's you can use a 4" self feeding drill bit and install snap in round louvers.
Old 05-29-2014, 10:57 AM   #3
Rob
Robpo's Avatar
Rewards Points: 826
The vents go in the under side of the over hang. If there is blocking on top of top plate it might me a code violation to remove them and not put them back some place.
Robpo is offline   Reply With Quote
Old 05-29-2014, 12:13 PM   #4
Rewards Points: 892
I could do the round holes, but again, the baffles require to be secured to the top plate for proper installation. I can't secure it to the top plate because the spacer is sitting on it.
Old 05-29-2014, 01:54 PM   #5
Another choice is to install Smart Vent.
Google it.
Old 05-29-2014, 03:20 PM   #6
Rewards Points: 892
I will look it up. Am I explaining my dilemma correctly? I could throw in circular vents in the spacers, but each only allow 2 in of air flow. Joke.
Old 05-29-2014, 03:23 PM   #7
Rewards Points: 892
I don't think the Smart vent is for my application. How does one keep their insulation away from their exposed rafter eave vents? That's my dilemma. I could drill holes in it, but the blown in cellulose would block it. The baffles won't work with insincerity occupies the top plate.
Old 05-29-2014, 03:54 PM   #8
Use this style baffle and hold it back to the inside edge of the top plate.
Why do you not think the Smart Vents would work?
Unless you cover up those tails your limited on what you can do.
A whole lot less mantaince if you close them up.
Old 05-29-2014, 04:20 PM   #9
Rewards Points: 892
I think I will just build a soffit. I didn't think it would work because according to their website, they control flooding water as well...
Old 05-30-2014, 12:03 AM   #10
Registered User
Rewards Points: 5,516
Use rigid foamboard at wall perimeters. Much better insulating the wall top plates as they are house AC'd and attic air is hot, sometime moist. Cut the whole top-edge of blocks out, (not code required unless more than 2x4 rafter/2x6 CJ, check local AHJ); screen it, small trim over screen.
Gary
Old 05-30-2014, 09:14 AM   #11
Rewards Points: 892
Gary
Do you mean rip the block? Take about an inch off and re-block it but screen the part I ripped off?
Old 05-30-2014, 10:26 PM   #12
Registered User
Yep, if the rafter ratio meets minimum code I gave. Pictures would help...
Gary
2x4 Rafter Question Texasdiyer Roofing/Siding 2 05-24-2013 10:12 AM
rafter spacing question markharmon Building & Construction 12 05-02-2013 08:12 PM
Fascia/Crown to rafter question Joe1. Building & Construction 1 08-13-2010 10:16 PM
Hip Roof Ventilation Question tecboy Roofing/Siding 7 06-17-2008 09:37 AM
Attic ventilation question tpagel Building & Construction 4 04-15-2008 12:22 AM
