10-04-2012, 10:49 PM
#1
radiant barrier - energy star compliant?
Regular radiant barrier at home depot $65.
Energy Star complaint radiant barrier $129.
The energy star stuff also weighs twice as much.
What is the big difference? I need to buy alot of it and I would like to know what I'm getting or missing if I pay double the price?
10-05-2012, 08:07 AM
#2
Exterior Construction
Radiant barrier as very climate specific.
Where is the home?
Tin foil is just as effective a radiant barrier as the thicker stuff and given that there are no tax credits right now, I would buy whatever is better and not what is "Energy Star".
10-05-2012, 02:16 PM
#3
The thicker stuff is just radiant barrier surrounding foam bubbles.
I am in the high desert and this is going under a sheet metal roof with furring strips to create a gap/air pocket. So no doubt about it I need radiant barrier. I have heard that radiant barrier is radiant barrier. Anybody who says theirs is better than others is not correct. Just wanted to double check and make sure.
10-05-2012, 02:26 PM
#4
The double bubble stuff makes not difference whatsoever from a radiant standpoint and there is zero insulation value (substantive at least).
10-06-2012, 09:27 PM
#5
Moderator
Clothes taking longer to dry?
10-07-2012, 10:19 AM
#6
Gary,
Did you mean that he should select the Energy Star version?
It appears that Energy Star can no longer be used when referring to radiant barriers by that pdf you linked to.
Maybe I misread in the 30 seconds I scanned over it...?
10-07-2012, 06:17 PM
#8
Ah ha!
My sarcasm detector was not on this AM before coffee.
10-07-2012, 11:37 PM
#9
Try emergency blankets, they're GREAT radiant barriers.
http://www.ebay.com/itm/50-Emergency...item2323275021
1500 square feet for $35
Flooring installer. Ecological Restoration Technician. Green Building Enthusiast. Obsessed with insulating.
10-08-2012, 07:34 PM
#10
www.homedepot.com
search term "radiant barrier"
select to compare
select the $65 kind and select the $129 kind
press compare
mecca model comes up
Energy Star compliant: No | Yes
That and the thickness seems to be the only difference between the two.
10-09-2012, 08:39 AM
#11
Thickness has nothing to do with the effectiveness of a radiant barrier.
Any claimed insulation value is worthless in this application as well.
If you are worried about shear resistance, than perhaps the thicker material is better. As an insulation, the radiant barrier makes not difference.
10-11-2012, 12:50 PM
#12
i bought the reflectix from lowes for $60ish per (4'x125') roll. I put it in the attic. they also sell the radiant barrier with bubble wrap in between foil layers but even the company told me, that will give you no added benefit in the attic. That stuff with bubble wrap or foam is more for walls as they claim a better R value. In attic/ceiling applications, you're mainly just trying to reflect the heat which as someone previously mentioned, alluminum foil by its self will do that. I'd go with the cheaper stuff for sure.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
