-   Insulation (http://www.diychatroom.com/f103/)
-   -   Radiant Barrier Dilemma (http://www.diychatroom.com/f103/radiant-barrier-dilemma-101078/)
thailen 04-10-2011 05:53 PM
I've been researching radiant barriers for my attic, which has 6" of floor
fiberglass insulation and noticed that there's a choice between single, double bubble barriers and layers of aluminum foil and other materials, with the cost the highest for the bubbles. Is there a significant difference in heat reflection, given the insulation already in place? Which should I buy?
HomeSealed 04-10-2011 10:53 PM
Where do you live? Radiant barriers are not a good investment in all locations... Regardless, you need to maje sure that you attic is properly air-sealed and insulated to code before giving it any consideration.
thailen 04-11-2011 04:23 AM
Where do I live?
In New Orleans, where summer usually lasts from April - November and winters are very mild.
SPS-1 04-12-2011 09:28 PM
I thought that radiant barriers in a hot climate were normally on the underside of the roof. The first result from a Google search seems to agree with me.
http://www.energysavers.gov/your_hom.../mytopic=11680
Gary in WA 04-13-2011 12:08 AM
Your 6" of insulation is about R-20, yet your area, Zone #2, requires R-30. I would air seal, as H.S. said, then add 1/3 more to at least the minimum Code; http://publicecodes.citation.com/ico..._11_sec002.htm
Gary
