01-17-2012, 03:08 PM
#1
R13 vs R13
Hey all, 1dumbquestion here with... well, a dumb question. I was looking at home depot for some insulation and they have R13 in 32' rolls or in precut batts. It's more than 40% more to buy them precut than in rolls. does that sound normal? Wow, now that I've typed it it really is a dumb question, it just seems that 40% is a lot to pay for act of cutting. Now that I've got your attention I'm remodeling an old house that had no insulation it has 2x4 walls and trusses, I was planning on R13 batts for the walls and spray in for the ceiling (currently there is no drywall so I could do something different). What is needed in the crawl space? I'm in Oregon. Thanks, 1
01-17-2012, 03:27 PM
#2
R13 vs R13
1D,
I just bought a bunch of insulation at HD recently and noticed the same thing. Needless to say I bought the rolls that weren't precut. You have to watch the big box stores, they many times have similar items but charge a lot more for a little convenience.
Mike Hawkins
01-17-2012, 04:01 PM
#3
R13 vs R13
convenience costs - isn't that the truth! I've found that the rolls work just as well anyway!
01-17-2012, 04:09 PM
#4
R13 vs R13
01-17-2012, 04:12 PM
#5
R13 vs R13
Oh.. I guess there still was a question to answer
Good call joecaption - taking care of business!
01-17-2012, 06:12 PM
#6
R13 vs R13
Just remember that R13 insulation in a wall gives you a wall much less than R13 (R10-11) because of the framing. Not like using XPS foam.
Dick
01-18-2012, 01:48 PM
#7
Moderator
R13 vs R13
Oregon has its own "specialty code" taken from the IRC prescriptive Code that Joe posted.
Always a good idea to check with the local AHJ. Notice R-15 is required below-grade walls, not listed R-13 on the other Code page.
http://energycode.pnl.gov/EnergyCodeReqs/?state=Oregon
http://ecodes.biz/ecodes_support/fre...Efficiency.pdf
Gary
Clothes taking longer to dry?
01-18-2012, 02:13 PM
#8
R13 vs R13
I think the OP was interested in doing the project properly and not to the typical code minimums or the pink panther way.
Dick
01-18-2012, 10:46 PM
#9
Exterior Construction
R13 vs R13
Dick
+1
Actually less for that matter. Even if you figure that your framing leaves a net clear of 80%, that still makes for and R-7.5 average.
01-18-2012, 10:55 PM
#10
Moderator
R13 vs R13
Good call, Dick. I'll get you started, don't use f.g.: The "biggest loser" in fiberglass insulation....
Gary
01-18-2012, 11:17 PM
#11
R13 vs R13
Just don't complicate it and get into the problems with steel studs that really contribute to thermal short circuiting and loss of insulation between the studs.
Dick
The Following 2 Users Say Thank You to concretemasonry For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
