R-Value Thickness Foam Board In Basement Floors/walls - Insulation - DIY Chatroom Home Improvement Forum
Old 01-09-2012, 02:41 PM   #1
Rewards Points: 150
R-Value Thickness foam board in basement floors/walls
Getting around to finishing my basement, I had some water issues previously but solved them by installing an interior french drain ( weeping system ) in to my sump pump and new gutter system.
It's been about a 9-10 months since these were installed and my basement is nice and dry.
When it comes to insulation for the floors and walls i'd like to use rigid foam board. What thickness is recommended for the walls and floors?
Due to space, and ceiling height i'd like to use the " bare minimum "
Would 1" foam board under 1/2 plywood for the floors suffice?
and 1" or 1.5" on glued to the walls with 2x4s in front with fiberglass insulation in between the studs work?
Im in central NJ, east coast... temps range from about 10 degrees F to 110 degrees F
thanks
alecmcmahon is offline   Reply With Quote
Old 01-09-2012, 11:47 PM   #2
Registered User
Rewards Points: 5,216
Find your Zone in the charts below the map: http://publicecodes.citation.com/ico...001_par001.htm
Find the wall/slab insulation requirements with the zone here; http://publicecodes.citation.com/ico..._11_sec002.htm
Do you have any exterior below-grade rigid insulation existing?
Or under-slab insulation?
Gary
Old 01-09-2012, 11:55 PM   #3
Rewards Points: 150
No current isulation. House was built in 1955. Cinderblock walls
Old 01-10-2012, 12:04 AM   #4
Registered User
And what R-value is required for your location?
Gary
Old 01-10-2012, 12:16 AM   #5
Rewards Points: 150
Zone 4. Looks like r13?
Old 01-10-2012, 03:30 PM   #6
Rewards Points: 660
What is your floor currently made up of? Concrete?
What do you plan to use as flooring? Carpet? Tile? Wood?
B
Beepster is offline   Reply With Quote
Old 01-10-2012, 03:38 PM   #7
Rewards Points: 150
currently concrete.
PLANNING on
1" ( or 1.5" ) rigid foam board
1/2" plywood
Laminate flooring
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Best adheasive for foam board to concrete BlueBSH Building & Construction 1 08-05-2011 04:06 PM
Foam Board on exterior of above grade house Sheldon General DIY Discussions 6 12-08-2009 05:05 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
