R 30 Insulation In Walls - Insulation - DIY Chatroom Home Improvement Forum
Old 12-11-2011, 10:19 AM   #1
ABS
R 30 Insulation in Walls
Can I install 91/2" thick R30 insulation in my 2x6 studded outside walls or will my R factor be reduced too much? We live on a very windy ridge and feel that R19 might not be enough.
ABS is offline   Reply With Quote
Old 12-11-2011, 10:24 AM   #2
Rewards Points: 13,300
Never put to thick an insulation in the wall. If it's compressed it's usless.
Old 12-11-2011, 10:32 AM   #3
Dont compress fiberglass batts to fit a cavity shallower than what the batt is designed for. No matter how much fiberglasss is compressed, it will not stop draftiness - been there, done that, had to start all over again. You need to stop the airleaks in those walls. Seal up all the stud bays with good quality caulk - wherever two pieces of wood meet. That still might not be enough - air is like water in that it will find a way through. If you block one crack, it will find another. All cracks need to be sealed thoroughly in pretty much the whole structure in order to make a difference. And dont forget about those plumbing/electrical holes and chaseways.
Hates my roof is offline   Reply With Quote
Old 12-11-2011, 11:41 AM   #4
Rewards Points: 6,652
I would use Roxwool, or Wet application dense pack in the wall space, vs. conventional insulation batts. Reason being, is that air moves too much through regular batts, along with noise.
The Following User Says Thank You to gregzoll For This Useful Post:
Windows on Wash (12-11-2011)
Old 12-11-2011, 12:16 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,112
+1
Batts are largely crap and if you get the high density stuff, they are expensive.
Old 12-11-2011, 12:23 PM   #6
I only used them in my bathroom when we remodeled, due to I had a bag left, when we went around and did the rim joists in the basement. I wanted the house to still breathe a little, but not airtight downstairs, so that is why I used Kraft faced R-13.
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 05:42 PM
betwin walls insulation omini Drywall & Plaster 4 11-14-2010 06:50 PM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
Basement walls and insulation hodak Carpentry 3 11-24-2009 01:58 AM
Rigid Insulation on the interior walls during remodel KHM Building & Construction 2 04-29-2009 10:08 PM
