R-30 Fiberglass Thickness Discrepancies - Insulation - DIY Chatroom Home Improvement Forum
Old 11-03-2012, 05:54 AM   #1
Rewards Points: 165
Hi all,
I searched the forums and didnt find an answer so I'm hoping someone here knows. I found two fiberglass insulation products with an R-30 value. One is a continuous roll (http://www.lowes.com/pd_177781-1722-...%7C1&facetInfo=) and the other is batts (http://www.lowes.com/pd_323807-1722-...%7C1&facetInfo=). How is it that they have different thicknesses (one in 9.25" and one is 10.25") but still have the same R value. It is only an inch difference, but I still am curious how they can both be the same but are different thicknesses. Confused......
chronojosh is online now   Reply With Quote
Old 11-03-2012, 06:52 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,092
3.25 is what most fiberglass is estimated at. The other one could be mislabeled or a low density vs. high density batt.
Old 11-03-2012, 08:20 AM   #3
Rewards Points: 165
Does the density make a difference in its performance? I looked at both in the store and they are at least labeled the same in store and online. I bought the rolls and I am planning to use them over the R-30 batts that are already in my attic. Thanks again!
Old 11-03-2012, 04:03 PM   #4
The higher density batts perform better in wall application because of their increased resistance to convection. Not sure it is as much of a difference maker as it applies to the attic applications.
Why not loose blow the attic?
Old 11-03-2012, 04:53 PM   #5
concretemasonry's Avatar
Rewards Points: 2,594
When you use batts to get an R30, you do really do not have a R30 ceiling because R30 is the theoretical/mythical insulating value of the insulation itself in a short term test in a laboratory of the insulation you install. The real value in place will be lower or much lower depending on the thermal "short circuiting" of the studs or joists (spacing and materials - wood or steel). - Also the installation of the batts does have a bearing on the effectiveness/ineffectiveness.
Dick
concretemasonry is online now   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
chronojosh (11-05-2012)
Old 11-03-2012, 09:52 PM   #6
Registered User
Rewards Points: 5,482
your R-30 has R-2.93 per inch: http://www.jm.com/insulation/faqs/1024.htm
Notice the different comparisons when compressing it from 1-2"; http://www.greenbuildingadvisor.com/...fiberglass.JPG
The high and medium densities are made by compressing their standard low density ones, that way they don't need to completely change the manufacturing machine set-up; Page 41; http://www.huduser.org/Publications/pdf/walls.pdf
Convective looping is inherent in low density wall insulation, pp 45: http://www.buildingscienceconsulting...Measure_Up.pdf
The density is very important, especially in loose-fill f.g.: http://www.homeenergy.org/show/artic...zine/77/id/910
http://www.greenbuildingadvisor.com/...ort/html/12484
You have convective loops in a vented attic space, cover the air-permeable fiberglass with a housewrap to stop feeding them; fig.7b, d, f, and h: http://digitalcommons.unl.edu/cgi/vi...ventilation%22
Help stop air leaks with cellulose or Roxul: http://bct.eco.umass.edu/publication...-smart-choice/
Air seal the attic first by looking for existing dirty f.g.; http://www.finehomebuilding.com/PDF/Free/021105092.pdf
Gary
P.S. further reading, if interested: The "biggest loser" in fiberglass insulation....
The Following User Says Thank You to Gary in WA For This Useful Post:
difference between fiberglass insulation for house and ovens Druidia Insulation 2 08-03-2012 08:44 AM
Removing fiberglass batts without fibers all over house darlingm Insulation 7 09-10-2011 09:47 AM
cellulose over blown in fiberglass? deerhunter Building & Construction 1 10-29-2010 10:16 PM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 07:48 PM
Is fiberglass insulation safe for us with dishwasher? jen78fl General DIY Discussions 10 01-31-2008 05:51 PM
