R-30 Faced/ Unfaced Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 01-05-2012, 09:01 PM   #1
R-30 Faced/ unfaced insulation
want to insulate R-30 between the trusses (22 in approx) should I use faced or unfaced insulation?......have to insulate between the tresses....no other way to keep the heat out during the summer
bhanse is offline   Reply With Quote
Old 01-05-2012, 10:51 PM   #2
Registered User
Rewards Points: 526
Welcome to the forums!
Where are you located?
Is this an attic application or a cathedral ceiling?
Gary
Old 01-06-2012, 07:52 PM   #3
R-30 Faced/unfaced insulation
I live in Menifee Ca about 60 miles north of San Diego inland off of the Interstate 15........the insulation will be installed on a cathedral ceiling.....over my garage.......bruce
Old 01-07-2012, 09:39 PM   #4
Registered User
Rewards Points: 526
So you have converted the garage to a living space? Cathedral ceilings require a ridge BEAM, not a board.... scroll down a couple of pages: http://books.google.com/books?id=E5S...raming&f=false
Have you a permit?
And, welcome to the forums!
Gary
Old 01-08-2012, 01:17 PM   #5
R-30 Faced/ Unfaced
No. 1...... My home has trusses for roof structure......No. 2.....My home has a storage space over my garage......and is accessed from my garage and is just over my garage......No. 3.....It is not a living space......No.4......I want to insulate between the trusses to help keep it a little cooler during the summer......No. 6.... This space will not be finished with Sheetrock or wallboard.......No, I'm not trying to be a smart guy or surly.....I'd just like to know if I should use faced or unfaced insulation
Old 01-08-2012, 01:37 PM   #6
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Look up "radiant Barrier", you would probably be better off using that rather than insulation.
I don't mean to seem surly either, I just am.
Andy.
AndyGump is offline   Reply With Quote
Old 01-08-2012, 07:29 PM   #7
Registered User
Rewards Points: 526
Unfaced for your location, Zone 3b.
Gary
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Foil faced rigid insulation question 123ozzie Insulation 3 12-11-2011 01:18 PM
New Unfaced Insulation Off gassing something common sense Building & Construction 3 10-07-2010 03:46 PM
Faced or Unfaced Insulation ? - Room below porch buchmana Building & Construction 2 02-01-2010 09:29 PM
faced or unfaced insulation for flat roof? crazychef55 Roofing/Siding 3 01-20-2010 08:11 AM
