R-19 In Attic/ceiling - Insulation - DIY Chatroom Home Improvement Forum
Old 04-05-2012, 08:45 PM   #1
Rewards Points: 1,062
Question
R-19 in attic/ceiling
my house is in the mid-Atlantic region.
i have 2x6 in my last floor ceiling and the attic between it and the roof is not used as the clearance is too small.
i was thinking of putting R-19 fiberglass insulation but was wondering if i should go thicker. i was also wondering that because, while the Owens Corning size sheet lists R-19 for ceilings, the wrapper says it is only for walls and floors.
http://insulation.owenscorning.com/a...7fb39eaf0a.pdf
thanks
Old 04-05-2012, 08:55 PM   #2
Rewards Points: 6,652
Blown-in is the best way to go, unless they are able to do Spray Foam, that would be even better.
Old 04-05-2012, 08:56 PM   #3
cortell's Avatar
Rewards Points: 504
Attic insulation should be a minimum of R50
cortell is offline   Reply With Quote
Old 04-05-2012, 09:18 PM   #4
Just a DIY guy
http://portal.ncdenr.org/c/document_...&groupId=38322
http://www.naima.org/insulation-know...installed.html
http://www.energystar.gov/index.cfm?...sulation_table
M3 Pete is offline   Reply With Quote
The Following User Says Thank You to M3 Pete For This Useful Post:
amakarevic (04-05-2012)
Old 04-05-2012, 10:53 PM   #5
hmm, i wonder why my HD even sells R-30?
Old 04-05-2012, 11:03 PM   #6
Usually if you buy enough (blow in) insulation the blow rental is free. Blown in is quick, easy, and typically cheaper than batts...
Justgaff is offline   Reply With Quote
Old 04-05-2012, 11:08 PM   #7
not applicable, i need to do it before hanging ceiling sheetrock. i do not have access to the attic, it is too small of clearance
Old 04-05-2012, 11:33 PM   #8
Could you use reinforced poly and low as you go? Sorry, I must not have read the post fully...
Old 04-05-2012, 11:40 PM   #9
i don't know what that is but i like to keep things simple and faced fiberglass insulation seems the way to go, i just staple the paper to the joists and off i go. blown in is too messy. i think i'm going with faced R-38, i need the paper to affix it to the joists before hanging drywall
Old 04-06-2012, 12:12 AM   #10
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
R=38 will be compressed in a 5.5" space, I think cutting the actual R value to less than that of R-19.
you should not do that.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 04-06-2012, 02:32 AM   #11
good point, however, that's the case only at the tapered end of the attic. as you go further away from it, the clearance heightens so at some point it starts having enough room for R-30 and even 38.
Old 04-06-2012, 11:17 PM   #12
Registered User
Rewards Points: 4,924
I'd add a foamboard baffle so the f.g. doesn't touch the roof deck above creating a "heat sink" AND ice dams. Use the foil-faced without an ignition barrier, ask your Building Department.
Gary
Tags
