Quiet Zone Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 12-22-2011, 12:39 PM   #1
Rewards Points: 79
Quiet zone insulation
Hello all,
Have anyone use Quiet zone insulation made by Owens Corning for sound proof purpose?
How does it perform compare to Roxul Safe and Sound?
Does it cause itchy on skin as same as regular fiberglass insulation?
Thanks in advance.
quincy is offline   Reply With Quote
Old 12-22-2011, 01:18 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Haven't used it.
Whats it made of? If it is fiberglass, you are going to itch.
The Following User Says Thank You to Windows on Wash For This Useful Post:
quincy (12-22-2011)
Old 12-22-2011, 02:21 PM   #3
AGWhitehouse's Avatar
Here's the cut sheet: http://www.owenscorning.com/quietzon..._DataSheet.pdf
It's basically standard fiberglass batt. insulation with a permeable facing for stapling that is not a vapor retarder. From the best I can tell, the only difference between this and a regular "faced batt." is the material used for the facing...The whole "quiet zone" aspect is more of a marketing ploy than an improved characteristic...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
The Following User Says Thank You to AGWhitehouse For This Useful Post:
quincy (12-22-2011)
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
3rd zone not working properly MichaelChlopik HVAC 1 10-15-2010 06:59 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
Boiler one zone call heat but not fire up Ballastar Plumbing 6 02-13-2010 12:17 AM
Boiler heating zone not working properly ssevern HVAC 5 12-19-2009 07:05 PM
