#1 |
Quick question about 4x8 foam
Hi everyone....I have searched this forum and everywhere else, but cant seem to find a solution....hope someone can help.
I live in a townhouse with poured concrete walls in basement, (middle unit) in Maryland, and getting ready to hang drywall. The front of my basement is 6' under ground and I'm stuck on what to do for insulation. I had to frame the walls 6" from the concrete wall due to plumbing so I'm wondering if I could use 2'' foam insulation on top of the concrete wall between the studs, just use batts, or should use both? Hope this makes sense..... Any help is greatly appreciated Jeff |
#2 |
There has to be 2 or 3 hundred post on this one subject. Please take the time to look at some of the older post.
#3 | |
Quick question about 4x8 foamQuote:
This is what I am doing (couldnt find the website earlier) http://www.buildingscience.com/docum...ion-assemblies The problem i have is that I had to start my framing 5'' from the concrete wall....after I install the XPS I will have a 3'' gap between XPS and framing....what can I use to make up that void? |
#4 |
What do you mean "due to plumbing"? What do you have there that you think the wall has to be ahead of? Pics?
B |
#5 |
Euro -
Just use the 2" XPS foam on the concrete and don't bother with the insulation in the stud wall wherever you decide to build the stud wall. In your climate, the soil is not that cold and you really would not be able to justify the cost of over-insulating, especially with batts that can hold moisture and feed mold if there is moisture. For the stud wall, make sure you use pressure treated plates on the concrete floor and appropriate nails/connectors. I assume this level is or will be conditioned space, so make sure you have air returns just off the floor. They can do wonders for uniformity and can benefit is you have AC. I have a single zone home with an open stairway and always can maintain a maximum temperature difference of 2F whether it is 100F or -20F outside. Dick Last edited by concretemasonry; 02-07-2012 at 10:06 AM. |
#6 |
You have this and the hijacked thread going at the same time on the same subject. Try and keep it to one thread.
Put the XPS against the foundation and leave small gaps by the plumbing to spray in behind them with 'Great Stuff'. Put the 2x4 framing right up against the XPS. No gaps. Gaps are bad. Where do you live? B |
#7 | |
| Display Modes | |
| Quick question with cement board and underlayment | supastar1568 | Flooring | 7 | 01-05-2012 06:03 AM |
| Quick Wire Size Question | leeave96 | Electrical | 5 | 08-22-2011 06:33 PM |
| Quick outlet question | RodBarney | Electrical | 5 | 08-20-2011 01:06 AM |
| New here! Quick question. | tmichelsons | Building & Construction | 5 | 06-15-2011 01:18 AM |
| Quick Bathroom Plug and switch Question | mclemenc | Electrical | 5 | 01-30-2011 11:02 PM |
