Question On Foam Board Installation - Insulation - DIY Chatroom Home Improvement Forum
Old 05-03-2012, 03:46 PM   #1
question on foam board installation
I have a question regarding installation of foil faced insulation board.
I am wrapping up construction of my 16' x 16' workshop/man cave.
6/12 roof pitch
composition shingles on 30# felt on 1/2" plywood on 2x6 rafters 16" o/c.
Part of ceiling joist are decked for storage, rest open (no ceiling/open attic/exposed rafters).
Want to install 3/4" or 1" foil faced insulation board between the rafters (as to leave rafters exposed).
Question: Can I install the foil faced (both sides) insulation board up hard against the bottom of the plywood roof sheathing without threat of moisture buildup?
Any advice or suggestions is appreciated.
ROB62 is offline   Reply With Quote
Old 05-05-2012, 02:47 PM   #2
Registered User
Rewards Points: 4,924
Welcome to the forums!
Will this spaced be heated/cooled?
Where is it located?
Gary
Old 05-07-2012, 01:19 PM   #3
Yes, plan on heating and cooling it at some point.
I am located in Northeast Texas.
Old 05-10-2012, 12:28 AM   #4
Registered User
If up against the roof sheathing, you would eliminate the venting space and it would be:http://www.buildingscience.com/docum...r-all-climates
No wood shingles or shakes: http://www.buildingscience.com/docum...rchterm=attic+
Gary
Foam board over old 4in thick fiber board roofing panels Rebob40 Roofing/Siding 2 03-05-2012 10:24 AM
Ridged foam board in attic, going for R-40 sentz Insulation 6 03-04-2012 01:27 PM
Why not remove kneewall batting and replace with foam board? fdecker Building & Construction 1 10-20-2010 05:46 PM
Venting foam board insulation mbscallen Building & Construction 5 02-15-2008 09:18 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
