Putting Up XPS On Basement Walls - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-18-2011, 01:16 PM   #16
Did use glue or screw the pretreated wood to the wall?
rickcet is offline   Reply With Quote
Old 10-18-2011, 01:18 PM   #17
Typed twice
Old 10-18-2011, 01:21 PM   #18
Rewards Points: 97
I did not glue/screw the fire blocks to the wall. I notched them just enough so that the top and bottom plates would hold them in place. Then after the studs were attached to the top/bottom plates, I screwed the studs and the fire blocks together.
leungw is offline   Reply With Quote
Old 10-18-2011, 11:20 PM   #19
Registered User
Rewards Points: 526
Here is valuable info on fire-blocking by Termite: How to fireblock framing
Treated wood is required on concrete but not against it: “7. Wood furring strips or other wood framing members attached directly to the interior of exterior masonry walls or concrete walls below grade except where an approved vapor retarder is applied between the wall and the furring strips or framing members.”---- http://publicecodes.citation.com/ico...9_3_sec017.htm
Gary
Old 10-20-2011, 08:29 AM   #20
XPS behind Electrical panel
Can XPS be installed behind a electrical panel or are there safety regulations not to do so?
https://picasaweb.google.com/lh/phot...eat=directlink
Old 10-20-2011, 08:39 AM   #21
Rewards Points: 97
My panel is in an unfinished room, and I left it alone.
Is your panel mounted directly on the wall? Can't really tell from the picture. Are you planning to finish that area and make an access window?
Old 10-20-2011, 08:55 AM   #22
Yes I plan on finishing that area. It is in the main room. I sent another picture to show how it is mounted. I plan on building walls around it with a door.
Old 10-20-2011, 09:09 AM   #23
Rewards Points: 97
I would leave that area alone and only put xps where there's a wall in front of it.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
How to frame basement walls with 9' ceiling jigglyman Building & Construction 5 03-14-2011 09:20 PM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 01:20 PM
Damp basement walls cjjjer Building & Construction 1 04-02-2010 04:18 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
