Pumping Foam In Cinder Block Walls - Insulation - DIY Chatroom Home Improvement Forum
Old 03-11-2014, 09:51 PM   #1
pumping foam in cinder block walls
There are businesses here in Phoenix that will fill your cinder block walls with foam to increase the insulation value. It is expensive. Are there companies that rent the equipment and sell the foam to do this yourself? Thank You.
beach_n_rides is offline   Reply With Quote
Old 03-11-2014, 10:03 PM   #2
Rewards Points: 13,444
Not a great DIY job.
I highly doubt there's anyone going to be renting out that type of equipment.
Old 03-12-2014, 06:41 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,984
Definitely not a DIY job to get it done right.
The DIY formulations of the product don't even exist out there nor am I sure it make a real difference or is it worth the investment.
I have seen it done and also seen it create unintended issues.
Water pipe to house. Do I check under cinder block ???? steve3847 Plumbing 10 12-29-2013 07:50 PM
Rigid foam on basement walls - gap or no gap? spaceman spif Insulation 9 10-19-2013 04:40 PM
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 08:26 AM
Tying in a 2"x4" walled-booth with a cinder block wall johnofthemount Building & Construction 3 12-19-2009 02:51 PM
2x4s on block walls Captflx Building & Construction 4 08-24-2009 08:25 PM
