Preventing Rot/Vapor Issues In Bathroom - Insulation - DIY Chatroom Home Improvement Forum
Old 05-01-2013, 12:57 PM   #1
Preventing Rot/Vapor Issues in Bathroom
The pictures show where the shower used to be. You can see the stucco is the only thing left in spots. The house is in zone 4c (Tacoma, WA), it was constructed in the early 1950s and the exterior wall, sill, rim joist and a few floor joists all needed to be replaced. Now that its done, it's time to insulate.
I was thinking spray foam would be best, but it's not in the budget. I have been researching Roxul and it looks like good stuff. It's 3-1/2" thick, R-15, and is unfaced. Any recommendations for the vapor barrier?
Since the original wallboard was rock-lath and plaster, it is more than 3/4" thick. To match the new with the old, I was thinking of using 1/2" polyiso foil-faced board under 1/4" drywall as the vapor barrier. I got the idea from Gary in WA in this thread (although in this case it's a ceiling.) insulating living space over garage
Any ideas or recommendations for the vapor barrier, or will my idea work?
Thanks,
Tom
Preventing Rot/Vapor Issues in Bathroom-img_6129.jpg   Preventing Rot/Vapor Issues in Bathroom-img_6122.jpg   Preventing Rot/Vapor Issues in Bathroom-img_7898.jpg
tomdor is offline   Reply With Quote
Old 05-02-2013, 11:26 PM   #2
Registered User
Rewards Points: 5,498
Good job! Just add solid blocking at the panel edges for shear as we are in a seismic zone.... I'll give you some light reading first, then discuss it; http://docs.google.com/viewer?a=v&q=...sNmmYf-psHZnLA
http://www.ewpa.com/Archive/2006/aug/Paper_296.pdf
http://www.buildingscience.com/docum...-analysis/view
Brainy membrane HEM_23-4_p37-40.pdf (application/pdf Object)
Describe the wall material make-up; http://www.buildingscience.com/docum...researchreport
Gary
Old 05-03-2013, 07:27 PM   #3
Rewards Points: 626
Man you did a fine job on fixing that!
Nailbags is offline   Reply With Quote
Old 05-04-2013, 03:10 PM   #4
Registered User
Other than the king stud/trimmer hinge joint at the old window double sill... with plywood keeping it in flex. Add a vertical scab to strengthen.
Gary
Tags
roxul , vapor barrier
Columbus Ohio Basement Full Bathroom -Post-Construction Compliance Hermi14 Plumbing 5 03-12-2013 07:11 PM
Rewiring Bathroom & Den heyjoe91 Electrical 4 02-21-2013 04:22 PM
bathroom exhaust connected to 26' of duct ChrisJJ HVAC 1 01-31-2013 10:50 AM
Exhaust Vents - Bathroom and Stove trophywalleye HVAC 0 03-19-2011 10:14 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
